Tachometer starts at the wrong end on idle?
Discussion in 'The Hokey Ass Message Board' started by davidh73750, Apr 16, 2012.
  1. davidh73750
    davidh73750
    I got a swap meet tach a while back and went to hook it up problem was it started at 8Krpm instead of 1K. I pulled the cover back and it was in 8 cyl position. green wire tach, red ignition, white light and black grounded.
    Any ideas? its a cool looking tach and I'd like to use it.
  2. dcwest32
    dcwest32
    you said Green wire tach, does this mean negative on coil ? because is where it should hook up
  3. davidh73750
    davidh73750
    I put the green on the HEI "tach" position.
  4. That is correct but what is it grounded to? Mine was doing the same thing until I put a direct ground to the frame.
    Good luck.
  5. davidh73750
    davidh73750
    it was grounded on the column. I made need to look elsewhere to ground it then.
  6. BamaMav
    BamaMav
    from Berry, AL
    That tach is for a reverse rotation engine. :D
