Hi Guys I got two of these WG 13-52-145 trannys sent from the states to me . One is going behind a y-block that will work fine . The other i thought would bolt up to a v8 . was told that all the stud patterns are the same . but now seems they are not . block id number 3956618 . Can i just get a different bellhousing and get it to work ?? cheers Peter <!-- / message -->
If the number is from the tag, the origin is '85-'86 Chevy S10, either 2.5 L4 or 2.8 V6. Both should have the same mounting flange pattern. If the number is from a casting, it doesn't mean anything for purposes of identification. Bob
