T5 Info
Discussion in 'The Hokey Ass Message Board' started by Flat Ernie, Jun 20, 2004.
  1. blowby
    blowby
    from Nicasio Ca
    Thanks Randy. I guess I will go for it as is. I almost made a shaft but with so many other things to do I just bought one.
    Paul
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Found some new info...I didn't think the input shafts varied that much. This info comes from part descriptions for replacement parts and is derived from overall length of the input shaft, so could be off by 1/16-1/8" (but unlikely).
    There are several different T5 input shaft lengths:
    WC
    6.625" - 88-92 Camaro V8
    6.725" - 93-98 Isuzu Rodeo
    7.125" - 85-93 Mustang, 88-92 Camaro V6, 88-92 Isuzu Rodeo, SOME '93 S10
    7.4375" - 85-93 Mustang/T-Bird 2.3/SVO
    7.875" - 94-95 Mustang V8
    NWC
    6.625" - 82-87 Chevette, 83-87 Camaro V8, Camaro/Astrovan
    6.725" - 84 S10 (2.2L), 82-84 S10 (Isuzu engine)
    7.125" - 83-84 Mustang V8, SOME S10
    7.1875" - Jeep, 82-83 280ZX Turbo
  3. blowby
    blowby
    from Nicasio Ca
    I'll post this here just as a reminder for others. If you are using a clutch disc not meant for your flywheel, make sure it clears the hub. I had to relieve my Flathead flywheel and knock the rivets down a bit for clearance. At least I discovered it before assembly.
  4. When I did mine I went to the Speed Shop and bought some different Flywheel Bolts with a lower head. I did have to trim a little out of the center of the flywheel with a hand grinder. It's been running for 8 years now with no problems
  5. Hi guys I did the S-10 tail housing swap on my 90 mustang T 5 now the rubber trans mount off the mustang dont fit it is wider than the S-10 so I go to NAPA they got nothing on to the chevrolet dealer $138.00 plus tax and have to order it NOT going to happen ! My question is does any other rubber mount bolt to the S-10 tailshaft I dont care about the crossmember I have a welder going to fab a new one any way.
  6. I got two of them from my local speed shop / parts store. It was just a universal one I think also fits some auto trans also. I can't remember who makes them, it was only around $20-$30. I can take a picture of it if you need.
  7. Shure pictures wold be awsome.
  8. Look at this trans mount Speedway 910-25820 it's a Polyurethane mount.
  9. Seabeebu3
    Seabeebu3
    I scored a wg 1352-145 today,, They were right $150
    Here you go, I think the 1036 is the part number.
  11. Mark T
    Mark T
    Does anyone have the bellhousing bolt pattern measurements for a Ford T-5?
    I'm looking for something like the picture below but I need the dimensions on the front of the trans where it bolts to the bell.
    I need the measurements for my Machinist so he can change the bolt pattern on my Y-Block bellhousing.
  12. Flatmik
    Flatmik
    from France
    I have a PDF file with a front view of an adapter for Ford BP T5 to "who knows" wich bellhousing. You have all the dimensions from the center of the input shaft to each hole on it.
    But don't know how to post a pdf, here ... :confused:
  13. Flat Ernie
    Flat Ernie
    Tech Editor
    You can attach pdf just like pictures
    Sent from my ADR6350 using H.A.M.B. mobile app
  14. Flatmik
    Flatmik
    from France
    Does it work ?
    I can't remember where I found this file, maybe somewhere around here ...
  15. Mart
    Mart
    Oui!
    Hope people are at home with millimetres!
    Mart.
  16. Flatmik
    Flatmik
    from France
    Yes, forgot to tell it ! The measures are metric ...
  17. nailheadroadster
    nailheadroadster
    Thank you for posting the info!
  18. Mark T
    Mark T
    Thank you for the information.
    I hope my Machinist can work with the metric system.
    Does anyone have this in inches just in case?
    Found it, thanks.
  19. Flatmik
    Flatmik
    from France
    1 inch = 25,4 mm. You should be able to make the conversion.
  20. nickleone
    nickleone
    Electronic to cable conversion on the T5.
    I bought a 94 T5 from a 3.8 V6 mustang. it has an electronic speedo drive.
    There is a white plug in the end of the electronic sender. I pulled it and there is a standard cable speedo drive under the white cap. The electronic connection also drives the cruise control etc. If you need to correct for tires/rear ratio etc there are small gearboxes that can be had to do a mechanical correction.
    Nick
  21. dondogarage
    dondogarage
    from richmond
    been reading for two days on t5 threads. I still need help found 2000 s 10 4wheel drive trany 5 speed would that be a t 5. owner cant find tag on tail housing . there is a bar code tag with #gaxr m002731 is that any help.
  22. not a T-5, its an NV1500 if a 4 cyl or an NV3500 if a 6 cyl
  23. dondogarage
    dondogarage
    from richmond
  24. nmartin2
    nmartin2
    Yes, I'm interested. I just received my first Hemming's Muscle Car mag last month, and I have T5 issues.
