T5 from behind a 4.3 will it work on a Chevy ii banger
Discussion in 'The Hokey Ass Message Board' started by willbierfarms, Jan 29, 2014.
  1. willbierfarms
    willbierfarms
    from palmyra mo
    Got the t5 out of a 96 s-10 with a 4.3 today and want to know if it will work behind a Chevy ii banger. Im so confused as to what will and what won't work
  2. oldolds
    oldolds
    Getting the bell housing might have made it a bit easier. Really no help other than that.
  3. hoop98
    hoop98
    from Texas
  4. gimpyshotrods
    gimpyshotrods
    That's not a T5. GM did not put the T5 behind the 4.3l V6 in any S10.
    You have a NV3500. You will note, it has an integrated bell housing. All T5's have removable bellhousings.
    That said, the Chevy II 153 and 4.3l V6 have the same bellhousing pattern and depth.
    It will bolt up, and you can use it, but you'd have to use a hydraulic clutch setup.
  5. gimpyshotrods
    gimpyshotrods
  6. scrap metal 48
    scrap metal 48
    Good info, gimpy...
  7. hoop98
    hoop98
    from Texas
    Are you sure?
  8. gimpyshotrods
    gimpyshotrods
    Yes.
  9. 4 banger 4 life
    4 banger 4 life
    from ohio
    Gimpy is 100% correct.. nv3500 was used behind the 4.3
    There is a big difference in the two apperance . The t 5 has a removable bellhousing were the nv 3500 does not.
    And earlier s10, s had a t 50.....
  10. hoop98
    hoop98
    from Texas
    Learned!! You would need a M-Van for that combo.
  11. gimpyshotrods
    gimpyshotrods
    Yup, and that combo ain't too common. The vast majority were automatics.
  12. Since it will bolt up, why not use what you have? It is the NV3500 as stated, but it has plenty strength for your Chevy II engine. BTW, it is also elec speedo
  13. gimpyshotrods
    gimpyshotrods
    It is a perfectly good transmission. The only issue is the lack of a mechanical speedometer drive. If you can work around that. Just use it.
  14. willbierfarms
    willbierfarms
    from palmyra mo
    Well I have one of each now if faced with the choice which way should I go I have to get a bellhousing for the t5 but have to spend no cash on the 3500
  15. hoop98
    hoop98
    from Texas
    Here are the 96 S10 M50 ratios.
