Technical T-Roadster toe board removal??
Discussion in 'Traditional Hot Rods' started by Bugsy, Dec 15, 2014.
  1. Bugsy
    Bugsy
    from Kansas
    I've searched forever and can't seem to find pics of removing the toe board on a T roadster to gain a bit of leg room. I know it's a simple process, obviously but would like to get some input and see a few pics of how it's done and gets some ideas about fabbing up the relocated board.
    Thanks!!!
  2. bct
    bct
    its riveted to the sub frame and firewall . its as much a brace (corner bracket) as a toe board . the 1/2" groove that the wood floor sits in continues all the way to the firewall so you can easily adapt the floor boards . myself I'd weld in a 90* angle at the end of the subframe and use the rivet holes to join the sub and firewall . not as strong as stock but its something. IIRC there is a flange already on the sub frame that has two rivets already in the firewall that may be enough if you don't have to cut it out for pedal clearance
