T Coupe rear axle width
Discussion in 'The Hokey Ass Message Board' started by poofus1929, Aug 11, 2011.
  1. poofus1929
    poofus1929
    from So Cal
    I am wondering what width rear end those of you that have built T coupes have used? I found a guy selling an 8 inch out of a 68 Fairlane. The plus is it's a smoking deal and the fact that it is from a 390 car so it should hold up to a small block no problem. The bad is that it is 55 inches from backing plate to backing plate and 61 inches over all. When I lay out a tape measure under the rear the 61 sticks out pretty far. I am still uncertain what wheel/tire combo I am gonna run on the rear and I know that it will effect the look of the rear. What have you guys used?
  2. Mr cheater
    Mr cheater
    the rear end on my T coupe is like 55 inches backing plate to backing plate out of a 55 Chevy. with 4 inches of back spacing on the wheels
  3. poofus1929
    poofus1929
    from So Cal
    Nice. It doesn't look too wide.
  4. HuffDaddy
    HuffDaddy
    I picked up a Ford 9" that's 58 1/2" long, drum to drum. I was told that it was out of a stepside pick-up truck.
  5. poofus1929
    poofus1929
    from So Cal
    That's what I'm thinking. Stick with the 9". I don't know too much about the 8's. I was told the 9's are a better axle.
  6. chaddilac
    chaddilac
    46 ford coupe banjo in mine.
  7. chaddilac
    chaddilac
    A ford 9" out of a stepside vs. shortwide/longwide would be the same width.
  8. Atwater Mike
    Atwater Mike
    For SBC, 8 is great; 9 is fine. If you're thinking about wheels, (OEM lug patterns and hub caps) the truck 9" has a 5.5" pattern, same as early Ford passenger, '28-'48, Merc '39-'50.
    The 9" in passenger cars (and the 8") have 4.5" pattern, but Wheel Vintiques makes a custom steel wheel with whatever backspacing you want, and it'll take the caps you specify.
    The 9" is a big strong unit, and I use them...but I also like the 8", it's strong and weighs a lot less...just not as many choices for lower gear ratios (you probably want around a 3.0 anyway, with a lightweight T and a 1:1 high gear ratio in the transmission)
    If you use an overdrive trans, you would use a lower gear ratio, lively in town and easy on the mileage on the freeway.
    Good things to consider...
  9. chaddilac
    chaddilac
    Mercury had 5x5 bolt pattern also.
  10. Atwater Mike
    Atwater Mike
    Yes, Chad, was it '55-'68? I used '56 Merc running gear in a '54 Ford Coupe in the '60s.
    Big brakes and I was able to bolt Buick wheels on it, (deep looking, with Buick Poverty caps...Everybody asked, "How'd ya do that?" Buick wheels were the cat's ass then...)
  11. chaddilac
    chaddilac
    I know 58 did... as I pulled a 58 merc rearend for my 59 olds for a swap... both have 5x5 bolt pattern!!
  12. poofus1929
    poofus1929
    from So Cal
    One of my buddies has the stock rear end out of his 49 Merc project just laying around. I looked it up and it says they are 61 inches over all width. I think this might be the one I try to pick up. Any idea of the ratio?
  13. need louvers ?
    need louvers ?
    Depending on how your building the car (fendered? fenderless?) I think your going to find a 61" rear end to be abit wide on a "T", especially if it has fenders. On a fendered car if you want to run most mag type wheels with a 3 1/2" backspace, we always shot for about 55"-57". if your running an early Ford wheel with it's heavier backspace, you can get away with more like 59". Of course with a fenderless car you can make it as wide as you want, but they start to look a bit goofy with the tires way far away from the body.
  14. MATACONCEPTS
    MATACONCEPTS
    I got a 56 chevy under mine. look for a S10 they're real narrow & readily available
  15. poofus1929
    poofus1929
    from So Cal
    It's gonna be fenderless. 61 inches does seem kind of wide. I'm definitely gonna investigate it a little further though.
  16. falcongeorge
    falcongeorge
    from BC
    If its an 8" it wasnt originally out of a 390 car, no way no how.
