The wipers on my `63 T-Bird are operated with a hydraulic motor which won't shut off. They worked (shut offf) until I replaced the fluid line that ran from steering box. The cable is connected and seems to be moving the arm on the motor. Any experts out there? Thanks
`58-60 T-Birds were vacuum, `61-62 were electric and then they went to hydraulic in `63 so that they could be adjustable to any speed depending on how much the valve was open. I ended up just taking it out and opening it up. The plunger valve was sticking so I cleaned it and put it back together. Its working for the time being.
