I have just instaled the t-5 behind my flatty and used the technical info that was posted on the HAMB.The article said that the 86-87 non world class should use straight 70-wt oil,not ATF.My question is where do you find this stuff? I have tried O'reilly's,autozone,GM and I'm currently at the NSRA nationals this weekend and the AMSOIL guy's are here and they don't know of such a thing,they did recomend synchromesh gear oil.can anyone help!! thank's jonathan
I just put Dex/Mercon in mine. Everything I've read says Dexron III, supposed to be the same as what I used.
ALL World Class T-5 use ATF oil and NOT heavy gear oil or Redline MTL! All NON-World Class T-5 use 70 wt gear oil. We recommend high quality Synthetic oil as it lasts a long time and over a larger operating temperature.
I run an old second hand non WC T5 behind a flatty, I run plain old Dexron ATF. Been beatin the crap out of it for years. Check the level once a year and look underneath for oil spots.
The original NWC did call for 70wt gear oil. Later, most of the mfgrs didn't differentiate between WC & NWC when specifying ATF. I run synthetic ATF even in my NWC boxes and have done for years. No issues for me so far. Shifts are smoother & easier with the ATF vs the 70wt oil. Some folks do report good results with Redline's MTL or GM's synchromesh in the NWC trannys...
Factory GM shop manuals say ATF regardless of year/application or WC/NWC. Synthetic ATF seems to be the preferred oil to use.
I tried synthetic in mine, but actually liked the feeling of it better with GM ATF in it, so I drained it and refilled it with Dextron III, although I do use a little additive in it.
I always ran syntehtic ATF in my 90 LX Mustang. I tired synthetic 70 weight once but it didnt shift as smooth. I used to drop the clutch at 5 grand with slicks and never had a problem with the ATF.
I use redline MTL. in my 2 NWC T5's. no problems. The Mustang kids I knew ran regular ATF and beat the shit out of them and occasionally lose 3rd gear due to driver enthusiasm, not lubricating problems.
