synchronized 3 speed w/overdrive against the original Model A engine, w/torquetube
Discussion in 'The Hokey Ass Message Board' started by manyolcars, Aug 25, 2012.
  1. thirtytwo
    thirtytwo
    Great conversion!
  2. Departed
    Departed
    from Canada
    Do you think that the short main shaft of the Jeep T-176 would fit in the T-170 gears and transmission ?
    [​IMG][​IMG]
    hotrodA likes this.
  3. RoddyB34
    RoddyB34
    Sorry Fabber the trans case is a cast iron one 3.03 mustang etc.
  4. Fabber McGee
    Fabber McGee
    I will still be using the stock Model A rear with 3.78 gears and 21" radials.
    According to the GrimmJeeper gear ratio calculator, with the T-176 I should be going 71 mph at 3000 rpm and 59 at 2500. 71 is as fast as I'm interested in going with mechanical brakes, even with the Flathead Ted kit... maybe a bit faster than I want, haha. I don't see any need for overdrive at this point, but I can always add taller rear gears if I decide to reduce rpm's.
    http://www.grimmjeeper.com/gears.html
    Very handy calculator.
  5. Fabber McGee
    Fabber McGee
    I think it will fit all the Ford top loader 4 speeds. I did quite a bit of research a couple years ago and that is what I recall, but my recaller sometimes lies to me.
    Beanscoot or someone else may know for sure.
    Departed likes this.
