Hot Rods Surface Rust?
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Jun 22, 2020.
  1. harleycontracter
    harleycontracter
    Just want to clean this up a bit. Not going to be a shiny build. What would work best Blast it or?[​IMG][​IMG][​IMG]
  2. Mr48chev
    Blasting would probably be the simplest. it would be rather hard to find a container large enough to stick it in and soak it with citric acid or another popular concoction.
    I used my Eastwood Contour on a fender on my OT daily that had the shipping coating on it and I got a bit slow about getting that off and priming and painting it right. Not that much rust but ugly. A bit spendy if you don't have a serous amount of use for one though.
  3. plym_46
    plym_46
    from central NY
    Concrete etching acid and scotch brites. I used muriatic outside and still was a bit rough on the old intake system. Got my over rocks nice and clean though.
  4. southcross2631
    southcross2631
    Dustless blasting will take about 30 minutes to make it look like new and they use a rust preventer to help against flash rust. the water in the dustless blasting helps cool the metal to help avoiding warpage that can happen if the blaster isn't careful.
    irishsteve likes this.
  5. Theres a utube video about a product called DRX.I have never used it so im just going by the video.It sprays on,and hoses off.
  6. Pats55
    Pats55
    from NJ
    This took 35 minutes. Spray it on.. Lay a paper towel over it spray it again let it soak. Follow it up with a wet scotch bright pad and dry it off. Note where it was spilled You then can store it indoors for a year without rerusting. Metal prep's that leave a zinc phosphate coating will extend the service life of your paintwork much longer.
    62SY4 and stillrunners like this.
  7. rusty valley
    rusty valley
    thats like ospho?
  8. mr.chevrolet
    mr.chevrolet
    looks like Ospho. Pics show Ospho in use and then painted with Rustoleum oil based paint.
  9. Pats55
    Pats55
    from NJ
    Ospho is a rust converter. If you leave it dry it leaves a iron oxide coating the Mastercoat prep is like they use in the automobile plants is phosphatides the metal and is ideal for body panels. They both are good products
    62SY4 likes this.
  10. A Boner
    A Boner
  11. harpo1313
    harpo1313
    from wareham,ma
    On the passenger side , Is that fire warpage?
  12. harleycontracter
    harleycontracter
    Hope not I don't think so
  13. alchemy
    alchemy
    I'd sandblast it.
  14. harleycontracter
    harleycontracter
    Did that today Came out pretty good ! Few pin holes Not bad
  15. alchemy
    alchemy
    And now all the pits are truly clean and the rust won't come back.
  16. A Boner
    A Boner
    Was probably too far gone to save any patina, anyway!
  17. harleycontracter
    harleycontracter
    Really wasn't any paint on it
