Supremes or cragar pro ss wheels
Discussion in 'The Hokey Ass Message Board' started by JakeDW, Dec 7, 2012.
  1. JakeDW
    JakeDW
    from Missouri
    I have a 61 unibody ford gona run skinny whites but I am stuck not sure what to
    run some Astro supremes or some cragar ss pro wheels.The truck will be on air ride and lay flat.
    Jake
  2. JakeDW
    JakeDW
    from Missouri
    Pic of the two wheels one is more hot rod one more custom.
    Jake
  3. JakeDW
    JakeDW
    from Missouri
    And we all know what these look like.
    Jake
  4. JakeDW
    JakeDW
    from Missouri
    Bought some 69 delux for it but kinda want some shine lol
    Thanks Jake
  5. ryno
    ryno
    Either one will look good. I'm thinking about supremes myself.
    Did you swap out your bolt patterns yet?
  6. JakeDW
    JakeDW
    from Missouri
    The front has a mm2 so it's 5 on 4.5 I was gona use adapters on the back till I get the disc on it.
    Rite now the front has adapters to fit the 5 on .5.5 delux wheels.
    Jake
  7. I always like those. Affordable to.
  8. Sidewinder777
    Sidewinder777
    from Dayton,Nv
    I am partial to supremes myself, guess it just depends on what look you are goin for on the build, good luck man :)
  9. Squablow
    Squablow
    Personally, I don't like those Cragars. They kinda look like an early magnesium wheel, but not quite. Not enough to pass for "traditional". And definitely not with skinny whitewalls.
    The whitewalls and Supremes will go together a lot better, assuming this truck is going to be a 60's or 70's styled custom or a lowrider.
  10. Brandi
    Brandi
    I'd say the supremes with skinny whites.
  11. JakeDW
    JakeDW
    from Missouri
    That is where my problem is I don't want it to look to much like a low rider lol
    The cragars are 160 each and supremes are 150 each.
    Nothing wrong with a custom look though.but really like the spinners ha
  12. Chuck-A-Burger Ryan
    Chuck-A-Burger Ryan
    Supremes with pinner whites
  13. SuRfAcE_RuSt
    SuRfAcE_RuSt
    ditto
  14. JakeDW
    JakeDW
    from Missouri
    What does a pinner white wall look like
  15. TERPU
    TERPU
    You gotta run real Cragar SS wheels if you are going to run those not what you picked. OR supremes with Pinner whites. The other Cragars just don't cut it.
  16. SuRfAcE_RuSt
    SuRfAcE_RuSt
    Pinner white wall = Skinny white wall
  17. JakeDW
    JakeDW
    from Missouri
    Ok so a lot of makers of supremes .
    What brand us wheel or Vintiques ?
    What offset / back space 3.5 or reverse
    How wide 7 I assume
    Thanks Jake
  18. JakeDW
    JakeDW
    from Missouri
    Lol I see
  19. Chuck-A-Burger Ryan
    Chuck-A-Burger Ryan
    Not sure what size will fit on your truck, I've run a 14x6 standard on my Comet and my Impala.
    A reversed might fit your wheel well and look goood.
    Anyway, I get my supremes from Coys. They carry AWC's which are strong because of the gusseting on the spokes. Not sure if you can get a reversed through them though. $120 ea.
    http://www.coyswheel.com/awc.html
  20. I just bought a set off TTO's for my 62 Unibody. Man was it hard to decide which way to go.
    I think the Supremes will look great on your truck, especially with the thin white walls. I was gonna go that way but decided to go of a more hot truck vs custom truck look.
    Make sure you show pics of your progress.
  21. marman1950
    marman1950
    15x7 supremes with 205/75/15 skinny whites....
  22. JakeDW
    JakeDW
    from Missouri
    My tires are 205 70 15
  23. JakeDW
    JakeDW
    from Missouri
    I have a build thread on here i hope to make some more progress soon I have most all the parts just need some time to get some work done lol.
    Jake
  24. JakeDW
    JakeDW
    from Missouri
    Think if I run a supreme it will look better with as much dish as I can get.
    Thanks for the link says 110 for a 15x7
    Jake
  25. JakeDW
    JakeDW
    from Missouri
    From the pic can anyone tell if its rev or a standard offset?
  26. Reveresed Cragar S/S or Supremes those Cragar wheels you posted look like shit. Just my 2 cents:eek:
  27. 296 V8
    296 V8
    from Nor~Cal
    "Traditionally"
    Supremes are barely one step above no wheels …. They are what you got if you couldn’t afford Crager SS’s ... then a bit later TruSpokes.
    People run them now like its cool ….. well it may be to some .. but back then it wasn’t
  28. Special Ed
    Special Ed
    Supremes were the ultimate wheel for customs in Southern California since the mid-sixties. Still are. Cragars were found on the more performance-oriented vehicles. At least that's what I personally remember. Your mileage may vary.
  29. Da Injun
    Da Injun
    Cragar SS. Not Crager....maybe I am a dick, but how stupid can someone be who is into cars and cannot spell Cragar properly?
  30. JakeDW
    JakeDW
    from Missouri
    Well when I grew up ss cragars belonged on a 78 firebird.lol
    Jake
