howdy folks,, I’m building a 1956 Fairlane and wanted to make my own Super Stock style leaf springs. The stock leaf springs have a Berlin Eye at the front so can’t add an extra leaf to run up to the centre line of the front bolt as there will be a 1/2” gap between the main and first additional leaf, or can I? I’m in the UK so just getting a new main leaf or buying custom ones isn’t that simple, any ideas? I’m building a sleeper so don’t want visible traction bars.
Hate to say this but look at cal- tracks or Chrysler years ago did a rod on top of axle and above the spring . Work like a 4 link with the spring being the lower link
A full length leaf can be added, see sketch of half Berlin eye. C1 Corvettes also had a link above the front half of the leaf spring, which IMO is preferable, also would not increase ride harshness.
These were the answer in the 50s and 60s. Looks like they are still in business, or simple to make yourself. http://www.tractionmaster.com/
A second leaf like what Desmodromic posted should work just fine as the front half of the leaves should be clamped. They will work best though with an adjustable pinion snubber.
Thanks man, hadn't thought of a Berlin helper, I'll measure what I've got to see if could make that Does the Vette style bar need a slider at all or are they all fixed?
NO! Seeing it's roughly the same length as the front half of the spring, there should be no binding. A slider would be a good way to commit suicide. LOL BTW, the Corvette radius rods were put there for hard braking. They didn't do much to stop wheel hop. Only way something like them might work, is with a super stiff lower spring, as in the aforementioned Chrysler leaf/ link system.
