Stupid? Wheel question....
Discussion in 'The Hokey Ass Message Board' started by CURIOUS RASH, Nov 13, 2012.
  1. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    I have some steel wheels that had light rust in the bead area, no pitting. I ro-loc'd the rust on out of there, getting ready to put tires on em.
    Is it better to paint the bead area or leave it bare?
    Thanks in advance.
    Sent from my DROID device using the TJJ mobile app
  2. pitman
    pitman
    Rashy,
    I would look into the phospho treating of the rim seal lip. Then it would less likely to re-rust.
    I suspect Metal-Prep or similar stuff.
  3. propwash
    propwash
    from Las Vegas
    factory and all other wheel manufacturers paint every part of the wheel unless they're ordered otherwise (ie: chromed or bare metal). If you leave it bare, moisture will get in there and you'll find your tires pinstriped with rust stains. And...moisture WILL get in there.
  4. Rashy,,I usually paint the bead area when I paint wheels. HRP
  5. flatheadpete
    flatheadpete
    from Burton, MI
    Good etching primer and then paint. At least the primer......
  6. big duece
    big duece
    from kansas
    I coated some like that with por-15, and hand sanded them. It helped "level" the surface and fill in the pits while sealing the metal.
  7. BOWTIE BROWN
    BOWTIE BROWN
  8. Take it from my painter, paint the beads. She has years of experience in this matter. :D. This was taken 4 years ago and they do not leak.
  9. CURIOUS RASH
    CURIOUS RASH
    I'll paint em up.
    Thanks dudes.
  10. 1/2done
    1/2done
    from Ohio
    If they're pitted much use bead sealer on top of the paint before you mount the tires
  11. I've smeared a thin coat of JB weld over the pitted areas to smooth the pits (after sandblasting). Sand down the JB smooth, then prime and paint the wheels. No chips, no rust, no leaks.
  12. dad-bud
    dad-bud
    Hmmmmmm, sounds like it's unanamous.
    Paint it is then.
