Stupid Question # 458 - Running stereo of battery ?
Discussion in 'The Hokey Ass Message Board' started by Mai Ki-Ki, Dec 29, 2003.
  1. Just wondering..as my stereo is killing my fusebox atm....isnt it possible to run the stereo straight off the battery with an inline fuse? (like the doof doof boys)
    Just use big guage wire or something>???
    Or is this a DUMB(tm) idea.
    Cheers
    MAIKI [​IMG]
  2. Guess what I'm asking is wheather thew charging system will cope...due to drawing straight from the battery...
  3. lowsquire
    lowsquire
    from Austin, TX
    if its blowin fuses yeh its probably a good idea to bypass all that 40yr old shitty holden wiring.....shouldnt cause a problem with it straight off the battery, as long as you put a fuse in.
    jeez maiki, you could just call and ask [​IMG]
  4. jerry
    jerry
    yes you can run the stereo straight off the battery. best to use an inline fuse for protection. no it wont hurt your charging system.
    i would use a relay in the line controlled by the ignition switch so that you don't run down the battery by leaving th eradio on overnite.
    jerry
  5. ..thought you were riding the big red tidal wave this week mr Squire Sir! Didnt wan't to poke the sleeping bear....
    Anyhoo u should be busy finishing that RPU b4 saturday!
    Looks like we may head down after lunch on Friday...and return Sundee....
    [​IMG] [​IMG] [​IMG]
