Stromberg question
Discussion in 'The Hokey Ass Message Board' started by model-a-fan, Apr 23, 2009.
  1. model-a-fan
    model-a-fan
    from Kentucky
    What caused this pitting on the bottom of the carb.? Is it safe to use or is there a proper repair method?
  2. uncle max
    uncle max
    Probably in it's dark past, it had the dichromate protective coating scuffed off and sat outdoors or in a rain-barrel. Once water comes in contact with bare potmetal, it doesn't take long for calcification to take over. I use an acid dip which leaves a barrier coating, pewter colored, impervious to water & fuel and should last another 70 years.
  3. model-a-fan
    model-a-fan
    from Kentucky
    Thanks max. So how do I determine if it's safe to use or not/
  4. model-a-fan
    model-a-fan
    from Kentucky
  5. strombergs97
    strombergs97
    Fill the bowl and if it doesn't leak, your good..
    Duane.
