History Stromberg Carburetor information desired
Discussion in 'The Hokey Ass Message Board' started by carbking, Jul 17, 2019.
  1. carbking
    carbking
    Continuing research into the surviving Stromberg documents.
    The following brass carburetor TYPES are listed in the parts indexes, but there is no record of their application. These would all be earlier than 1920. If anyone has one of these Stromberg carburetor types, and a factory parts book, owners manual, shop manual, etc. showing either application or parts break-down, I would like to acquire copies.
    Types are:
    E (I know these were used on early Stearns, but no documentation)
    F (believe to be experimental only, not certain)
    GA
    GB
    GC
    GE (believe to be experimental only, not certain)
    HA
    HC
    SK
    The Stromberg application database currently stands at 11,327 different carburetors. I still add 1 or 2 each month as I check additional documents.
    EDIT: I should have mentioned that all of these are UPDRAFT carburetors. The E was reused in the early 1930's as a downdraft type.
    Thanks in advance.
    Jon
    Deuces likes this.
  2. Jon,
    Have you checked with Stan Howe about any of these models? He mainly restores brass era carbs.
  3. TagMan
    TagMan
    AACA library in Harrisburg, PA. Might be able to help you out.
