Projects Stripping the gunk...
Discussion in 'The Hokey Ass Message Board' started by RUSS BUCKLIN, Apr 18, 2018.
  1. RUSS BUCKLIN
    RUSS BUCKLIN
    from Seattle
    Got 68 years worth of oils, grease and dirt build up under my 50 chev deluxe. Outside of hammer and chisel, is there a decent way to get most of this off?
  2. B Ramsey
    B Ramsey
    Rent a HOT pressure washer and get some old clothes from Goodwill. Go nuts.
    Flathead Dave likes this.
  3. 50 Fastback Fleetline
    from Milan, TN.
    If are trying to remove the old factory applied under coating you're going to have to scape, and in some places chisel that stuff off, I don't think it was meant to be removed. That was the worst part of doing my 50'
  4. williebill
    williebill
    Fire and explosives.
    kidcampbell71 likes this.
  5. Hollywood-East
    Hollywood-East
    Depending where you live, home depot parking lot around 7:AM
  6. Bandit Billy
    Bandit Billy
    Coin op pressure washer, so you don't have to clean up the driveway when your done. Bring your floor jack and jack stands.
  7. wvenfield
    wvenfield
    A pressure washer will just make the grease clean.
    Vanness and bchctybob like this.
  8. squirrel
    propane torch or heat gun, putty knife, and lots of elbow grease.
    Hot Rod Nut likes this.
  9. bchctybob
    bchctybob
    ^^^ what he said ^^^
    I use a large Exacto handle with a flat (shovel) blade mostly, or a sharpened stiff putty knife. Try scraping it cold, then try it heated, sometime it just pops right off cold. It's no fun but I just do an area at a time, take a break then do another.
    After it's all scraped, wipe it with pre-paint wax and grease remover or lacquer thinner and it should be nice.
  10. rusty valley
    rusty valley
    be happy its there, usually the frames are in nice shape under the gook....glass half full
  11. Hot Rod Nut
    Hot Rod Nut
    Ahhh... the Fun Stuff. Enjoy.
  12. 29moonshine
    29moonshine
    ^^^^x2
