Technical Stripped Allen head into Aluminum head
Discussion in 'The Hokey Ass Message Board' started by Budget36, Apr 23, 2019.
  1. Budget36
    Budget36
    This might help others out in the future.
    I understand my issue here is a steel (of what kind I don't know) blt into Al.
    Will heat (O/A) break up the galvaniatic? reaction and allow me to get it out? Working in a tight area...I could probably get a 90* die mini grinder and get to it, just holding a heat shield on, but if heat will do it, it would save me a few bucks on buying a tool I've never needed for all these years.
    Thoughts, experiences?
    Thanks
  2. 19Fordy
    19Fordy
    Pretty difficult to respond without a photo of the problem.
  3. RichFox
    RichFox
    When I rode a Honda, I learned to always give bolts and screws threaded into aluminum a sharp wack with a big hammer to break the oxide loose. After that they almost always came right out.
    Deuces, gas & guns, mad mikey and 3 others like this.
  4. Photo ???? is worth 1,000 words and some were already used up ....
    Deuces and Texas Webb like this.
  5. BJR
    BJR
    Anti seize is your friend.
  6. Budget36
    Budget36
    Well...two things...I'll try to get a photo...and this was put together 18 years ago...not sure a photo would help.
    Rich, can't get a whack at it...only about 4-5 inches between the head and the firewall.
    Main thing I was wanting to know if heat would do it like steel does...not used to this hitech Al stuff;)
  7. Budget36
    Budget36
    I'll find out in an hour or so if heat works, Will report back...gonna happen to someone else I'm guessing.
  8. Can you get a long punch in on some of the bolt head to smack on it?
  9. RichFox
    RichFox
    I bet heat will work as well.
  10. Budget36
    Budget36
    Letting it cool now...Punch might work, but I'd be banging the head of the Allen on the side.
    Last resort I'll torch it out...gotta get this thing out of the driveway...lol
    Thanks all
  11. Budget36
    Budget36
    Heat, heat, the magical fruit, the more you use, the more...
    Anyways, never heated a bolt to get it out of Al before, but it works like steel vs CI...heat red, let it cool completely and take it out.
    Now, just FYI, the Aleen head was semi rounded out, to where I had minimal grip on it...moral of the story is if it starts too tight...get another game plan.
    Thanks again all.
    And Rich...back in my 2 stroke days...my dad came up with an impact driver...man,. I think that cost about 12-15 bucks in the early 70's...now you can get them for like what...a 5 spot at HF?
    Times have changed;)
    loudbang and pprather like this.
  12. Heat worked on the thermostat housing bolts in an aluminum SBC manifold, when I did that last. Kept heating the bolt only, and let it soak down into the stuck area. Heated it again, and again. I also wire brushed the exposed area of any residue. Let it cool down a bit, then threaded the broken bolt out.
  13. Budget36
    Budget36
    Yes, heat did the trick...was concerned about it being into Al., but worked just fine.
    Hnstray and belair like this.
  14. noboD
    noboD
    An impact driver is a very useful tool. When you replace the bolt use never seize as someone else has said.
    mad mikey likes this.
  15. If you have access to it externally, hammer a 6-point socket over it and give it a turn. If it protests, go the heat route. I use never seize on every fastener on my cars.
  16. Another good tip is to chase the threads with a tap, before installing a new fastener.
    Vic
  17. 1-SHOT
    1-SHOT
    from Denton
    If you have room, get a uncoated nut that will fit over the Allen, bolt or stud (it will work on all 3) then thru the hole in the nut weld it to the Allen. Now the important part let it cool completely preferably over night , then take a wrench and back it out.
    The MIG weld will not stick to the aluminum, you may get some spatter holes in the aluminum but the threaded portion will come out. I have done on 3/8, 5/16, 1/4-20 and some smaller.
    THE IMPORTANT PART IS LET IT TOTAL COOL, always leave it over night BEFORE YOU FXXX WITH IT.
    mad mikey and Bandit Billy like this.
  18. Bandit Billy
    Bandit Billy
    ^^^^^I have had to do this before and I found that it is easier to cut the nut in half before welding it to the Allen. My MIG wouldn't penetrate the Allen as it was over attracted to the sides of the nut. The thinner nut was much easier to weld. And I didn't let them cool, I backed them out with an impact wrench while they were toasty hot. These were on a HD brake caliper on a bike of mine and not a head though to be clear.
  19. Deuces
    Deuces
    Try a metric Allen wrench...:confused:Sometimes it works... ;)
  20. Budget36
    Budget36
    Thanks all, just to recap...there was no room for me to try and weld anything, just enough for me to get my torch tip in an heat it up. After it cooled, came right out.
    As I mentioned before, I'd never done this with Al, so didn't know if it would work or make it worse...but it worked:)
  21. Deuces
    Deuces
    Good job!... ;)
  22. wahoo
    wahoo
    When I have a stripped allen head bolt, I try to find a torx bit that is a little bigger and hammer it into the hex. Then put a rachet on it. Works most of the time, especially on smaller bolts, set screws, flat heads and button heads.
  23. You were lucky. Anything that threads into aluminum gets anti-seize, without fail....
  24. chrisp
    chrisp
    Like Wahoo said, that's the best, it never let me down if you have the room to hammer. No mess, no risk of burning anything.
  25. Yes however it doesn’t help unless you put it on before it gets stuck. If you do and it doesn’t get stuck then we don’t know for sure :p:D
  26. 1-SHOT
    1-SHOT
    from Denton
    The weld a nut is the last resort before you have to drill and tap it . Unless you have access to a EDM.
