Straight front axle - I don't know what brand it is from and really don't care to check any further into it. There is no car brand or part numbers on it, and I KNOW if it was a Ford,it would say so. I GUESS it to be from an early Mopar due to bolt pattern. It is 50-1/2" from inside of drum to inside of drum which is appx. 1-1/2" wider than a Ford econoline. The spring perches are on 28" center. The drums are 10" diameter. The steering arm is still there, or make a custom one. The brakes need to be completely redone I'm sure. It is already 5x4.5 bolt pattern so that is better than a 4 bolt Ford also. first $250 takes it. "--- IF IT'S STILL LISTED, THEN I STILL HAVE IT - ----THANKS FOR LOOKING. >>>>>>>>>>>>>>>>>>>> David- phone#- PLEASE DO NOT TEXT- 8 5 SIX- 6 9 three- 091eight, 9am-9pm, IF YOU LEAVE A MESSAGE , please speak clearly , I am a 12 hour shift worker so be patient. >>>>>>>>>>>>> LOCATION-Pennsville, NJ,--- 5 minutes from base of Delaware Memorial Bridge- Routes 40,140,295,130& 95(NJ Tpke.) all come together here in Pennsville, so I am easy to find. >>>>>>>>>>>>>>>> seachwords-HOT ROD hotrod streetrod street rod rat ratrod Chevrolet Chevy Buick Olds Oldsmobile Pontiac Cadillac Mopar Dodge Chrysler Plymouth Desoto Ford Mercury Lincoln
