Projects Straight or 90 dist wire ends
Discussion in 'The Hokey Ass Message Board' started by Boden, Sep 29, 2019.
  1. Boden
    Boden
    Can someone send me some pictures of 8ba flatheads with straight and 90 degree spark plug wire ends at the distributor. Thanks a lot. I have both straight and 90 degree ends and can’t make up my mind. Haha
  2. Straights would be traditional... The 90 degree ends didn't start showing up in any numbers until the mid-'50s when hood lines dropped as the cars got lower/wider.
    Boden and seb fontana like this.
  3. pprather
    pprather
    I agree with Steve that straight distributor boots were more traditional. I think the right angle ones were not factory common until late 60's.
    Phil
    Boden, lothiandon1940 and seb fontana like this.
  4. Boden
    Boden
    Ok. Straights it is!
  5. pprather
    pprather
    A hint. For those with GM HEI, use straight spark plug boots at distributor end of wire set. This takes attention away from non traditional distributor.
    Phil
    Truck64 likes this.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    I also heard that electricity didn't like to make sharp turns before 1965. Jack E/NJ
    firstinsteele likes this.
  7. Truck64
    Truck64
    from Ioway
    In a way, that's actually kind of true. If you look at the earliest radio or electronic equipment from 100 years ago, they had all the wiring laid out all purty nice and neat like plumbing or a schematic diagram. They soon discovered that the shortest lead wiring worked a whole lot better, and the "bowl of spaghetti" or rats nest wiring mess was born.
  8. Boden
    Boden
    [​IMG][​IMG]. I got both. I kinda like the angled more. But I feel the straight will look better.
  9. denis4x4
    denis4x4
    from Colorado
    Not a V-8, but traditional none the less DD67211B-F7A7-4D51-9E31-7182B1F71FFB.jpeg
  10. 55styleliner
    55styleliner
