Technical Straight axle installation in 65 F-100
Discussion in 'The Hokey Ass Message Board' started by winr, Feb 2, 2017.
  1. winr
    winr
    65 F-100 ....... If I were to install a straight axle in the same place and same dimensions as the twin I beams would my draq link, drag link to pitman arm and steering box still work ok ?? ................ here is what the factory set up looks like
    http://www.fordification.com/tech/images/mydiscbrakes06.jpg
    Also, with a straight axle instead of twin I beams could I substitute coils over in place of the springs and shocks ??
    http://www.hotrodders.com/tw/images/e/e2/3-1_Ford_I-beams.jpg
    Here is a 57 Ford Gasser with coil overs
    http://customrodder.forumactif.org/t218p45-1950-s-ford-gasser
    Hope this is ok to post here
    Ricky.
  2. 55willys
    55willys
    Yes it could work. What kind of axle were you going to use? If this thread gets deleated just PM me
  3. winr
    winr
    Hey 55willys
    An early ford axle or perhaps a tube axle
    Is there another section I could put this in or does this not belong on the HAMB ??
    EDIT:
    Another angle
    http://www.mustangsteve.com/twinbeamremoved.jpg
    The passenger tie rod connects to the pitman arm
    The driver tie rod connects to the passenger tie rod
    Perhaps a one piece draglink to both spindles
    Then a link to the above from the pitman arm ??
    Regards and thanks !
    Ricky.
  4. okiewelder
    okiewelder
    from central Ok
    You just missed the factory straight axel by a year. Why dont you just use a older frame? should be one in a few salvage yards down your way .
  5. R Pope
    R Pope
    I was going to weld the twin I-beams together to make a single axle while keeping the disc brakes, sounds spooky but the local machinist said it would work. The later Twin I beams are welded up from formed steel.
