Did a search and can't find the answer. I am an idiot with some wiring issues so I need some help. yeah, yeah I know stereos/radios might not be totally trad, but what the hell, the car came with a radio in it when I got it in '74. 56 chevy radio converted to AM/FM. Speaker wires available for 2 front speakers, 2 rear speakers. I will use 1 front and 1 rear. So, there is one pair of wires for each speaker. The speaker has 2 pair of wires coming from each speaker. Speakers are 6x9 dual voice coil speakers. How do I wire the speakers?
show pictures of the speakers ..even if they had 4 voice coil there should only be 1 + and 1 - on each speaker if there is more just hook up all the positives to + and all the negitives to -..
One side should be (+) and the other being (-), most likely. If you can't post a picture, the model number and brand should help find some info on it. If the terminals aren't labeled, it really won't make a difference as long as your wiring one side negative and one side positive and since it's basically alternating current that causes the speaker to move and make noise. Also, running one wire to operate both voice coils should be fine.
What type( brand and model ) speakers are you planning on running? If they are truly dual voice coil( not doubting you BTW ), They will have 2 sets of input wires( as you described ). You could simply run the front left and right wire pairs( + and - ) to each set of terminals on the speaker. left front pos and neg to one one set of terminals and front right pos and neg to the other set. Then simply do the same for the rear speaker. This way you are running all four sets of wiring to just two speakers. You will not get the stereo separation of the speakers mounted apart, but will get the stereo signal keeping you from having gaps in the sound( like when instruments are located on different sides of a recording studio for example ). Dual voice coil 6x9's aren't that common in car audio, but I have seen DVC speakers made for ceiling mounts in homes and businesses. If you need to identify the positive and negative wiring coming off of the speakers, quickly touch the pair of wires to a nine volt battery and release. The speaker cone should move outward when wired correctly. Another option would be to use 4 smaller speakers in pairs( like 4 inch coaxials ) mounted onto a plate made from wood, that will fit in the factory speaker locations. Then just wire the 4 speakers like normal.
any number of devices that allow you to (barely) hear ZZ Top and the like over the exhaust at highway speed
here we go. I assume red is +, black is - but I dont know what is = and - from the stereo - those wires are gray, white, blue violet..... any suggestions welcome
You won't blow up the speakers if you wired them wrong. You would think you could get a test light and see what wire is what +,-. If that don't work hook them up and see what sounds the best and leave it that way. I've done that guessing game before with speakers when I was younger, switched them back and forth found what I liked and they sounded great. call 911 if any problems may occur LOL!!!!! ( Maybe an Ohm meter and go to a ground off each wire with the power shut off. You would think that would tell you what is -.... Good Luck
Those speakers were ment to replace an old-style mono (one) original factory speaker...but in a car equipped with a more modern left & right channel radio (stereo). So you could hook up your newer radio left and right channels to just one speaker, if you only have one mounting location. That doesn't sound like your case, so if you have two of those speakers, just mount them where you want, run the right channel wires from the radio to the right speaker, and the same for the left. Ignore the extra terminals/wires. You'll only need 2 wires to each speaker. If you have only one speaker, but a stereo radio, connect the left and the right leads out of the radio up to that one speaker. The wires coming off the radio should be labeled Right +, Right -, Left + and Left-. If not, do a search on google to find out what your wires and which side L or R are based on the model. Search for something like "kenwood speaker wiring". I've had some luck finding schematics like that. Make sense? http://www.casmfg.com/DVC_Speakers.htm .
on the speakers ya run + to + and - to - but this isnt your problem sounds like your stereo only has 1 wire per channel ..if this is correct i think you can ground the - and use the 1 wire from each output on the stereo show me a picture of the wire harness from the back of the radio..on a good stereo there is 8 wires 2 grey 2 white 2 purple and 2 green usaully for every 2 wires 1 is + and 1 is - now for the fronts you will run the solid white to the - and the white black to the + on the left front speaker do the same for the grey but its to the right front rears are left rear i think is green and right speaker is purple than you got the red 12v key on yellow 12v constant solid blue is remote to turn on a amplifier blue with a white stripe power antenna led black always ground sometimes theres a orange for dimmer dont use it .. that should help you out preety good .. let me know just looked at the wires again is the stereo you are using one of those factory chevy replacments??? if it is than the wires you have are ment to plug into the factory gm harness.post a picture of the back of the stereo and wires so i can see .. went back and re read this again ..you are only asking to run 1 speaker in front and 1 in the rear and there 6x9's dual voice coils just jump on the 6x9 + to + and than on one of the side + to the stereo than again on the - side same thing ..should work fine
Looks to me like the speaker has two sets of connections on it, one pair is Right, the other pair is Left. So you just connect the Right wires to one side of the speaker, and the Left wires to the other side. If the terminals on the wires are the wrong size, cut them off and crimp on the correct size terminals.
I have been installing stereo's professionaly since 1987, lorodz has your answer nailed with the exception that the speakers will be wired backwards which will cause no ill affects. White is actually left front positive, white/black is actually left front negative, etc...
If the stereo is set up for four speakers and you only run two, don't you use either just the wires for the rear, or the front, only (it makes no difference which), and wire one as left and one as right? The other wires just tape up the connections and don't use them, and if it has a fader turn it all the way to whichever direction you wired it for. At least that's how I'd try it. You can usually get away with powering the radio and doing some trial and error connections without hurtning anything. At least that's what I did on a '99 GMC a few weeks ago. I got the CD player installed and discovered it was a very user-unfriendly piece of crap (I couldn't even figure out how to reset the clock), so I let it go with the van.
yea sorry about the mess up with the positive and negitive ..havnt wired a stereo in a while ...but either way if you did it the way i said or the way someone else said as long as all the positives were on positive and negitive on negitive it should work fine ....hope all this helped
