Technical Stephens overhead valve conversion to flathead v8
Discussion in 'Traditional Hot Rods' started by carshopowner, Jan 6, 2012.
  1. carshopowner
    carshopowner
  2. I saw these on youtube and searched the HAMB to see if it had been posted before and I came across your thread, so bump.
    <iframe width="640" height="360" src="//www.youtube.com/embed/PGbXF4lD_pg" frameborder="0" allowfullscreen></iframe>
    <iframe width="640" height="360" src="//www.youtube.com/embed/21kd_wkR9V0" frameborder="0" allowfullscreen></iframe>
    <iframe width="640" height="360" src="//www.youtube.com/embed/eHs5-F_IMjo" frameborder="0" allowfullscreen></iframe>
    Stogy likes this.
  3. draider
    draider
    from Texas
    Very cool, I hadn't heard of Stephens before. I wonder how many sets they produced? They look like true hemispherical heads? Also looks like there's not much oil getting to the topend.
  4. Bearing Burner
    Bearing Burner
    from W. MA
    I saw an add for Stepheds heads in an early '50s Hot Rod. I never knew if any were ever made. First pictures I have ever seen.
  5. That's something you don't see everyday.
  6. the-rodster
    the-rodster
    Those are some ginormous valve covers.
    Very cool.
    Rich
  7. Devin
    Devin
    from Napa, CA
    Wow! Those make arduns look commonplace. Thanks for sharing
  8. kyvetteman
    kyvetteman
  9. Is it just me or do those videos have no sound? :(
    Edit: Nevermind, got it to work. Sounds gooooood! And looks even better.
  10. Mart
    Mart
    I love it. hopefully it will get fitted into a car. Neat to see it run with the cover off. I never heard of that conversion before.
    Mart.
  11. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Very cool. That engine needs to be in a Hot Rod.
    From Youtube;
    This is 1 of 4 known to exist. Speedy Bill has one in the speedway museum. Made in Denver. Originally made in the 50's for the pikes peak hill climb. Mounted on a 59AB flathead ford.
    ghornbostel likes this.
  12. flatheadkid1
    flatheadkid1
    from OHIO
    Here is the car that ran Pikes Peak in the early 50's. They weighed too much and flowed too poorly to be really competitive despite the huge valves (1.813") and hemispherical design. They cost $750. That was in 1951, I believe.
    I have to check my facts but I believe the car that ran pikes peak sucked a valve. Not sure if it finished the race or not.
    The whole engine is 32" wide.
    The engine at the Speedway Museum is the only example of the few remaining that uses a 2X2 intake. The rest are 3X2.
    The valve covers in the pikes peak car were the only known examples of that design and have been lost to time.
    Speedways engine is shown for comparison. Speedway has the original patterns which can be seen behind the engine.
    j-jock and Stogy like this.
  13. Zombie 51
    Zombie 51
    from New York
    That thing looks like a BBQ. Its kind of beautiful and ugly at the same time.
  14. loudbang
    Those LONG rocker arms on the bottom section look like they would have failed pretty quickly.
  15. flatheadkid1
    flatheadkid1
    from OHIO
    They did break.
    Original Shephens piston is shown in the background.
    I'm not sure who owns the Stephens in the video but it looks great.
  16. thanx for reposting, missed this
  17. They don't appear to be any longer than those from an Ardun, although they definitely aren't as well designed.
  18. loudbang
    For sure the Ardun ones look better designed. The Stephens just have a wide section in the center of the arm while the Ardun's have thicker material on the top and bottom where most of the forces would be directed.
  19. [​IMG][​IMG]
    Seen out a pinkee's before the good guys show in northern colorado
    Full Kustom, drunk mobile posting
    Stogy likes this.
  20. Mart
    Mart
    Great to see one in a car. Is that the same one as in the video? All that running on the test stand may have not done it much good.
    Mart.
  21. Jet96
    Jet96
    from WY
    IMG_6828.jpg This ran at HRHC last year, sounded pretty healthy. I can't download the video...
  22. topher5150
    topher5150
    what angle are those valves pointed at, they almost look sideways
  23. The motor in that video is in that 34 3w, Don Palmer, he attends the Hot Rod Hill Climb frequently. He got called out of town this year for work. It's one bad ass motor! Some where there is a video of it running up the hill at the Hot Rod Hill Climb.
    -nick
  24. typo41
    typo41
    The Lattens run one,,
    And I know of another set,,,,
    jimmy six likes this.
  25. The37Kid
    The37Kid
    They sold for $750. new.
    Bob
  26. $um Fun
    $um Fun
    from Nor Cal
    The one that Jim Latten runs are made by him. He has the patterns to them and had them on display at the LARS a few years ago.
  27. e1956v
    e1956v
    Alliance Vendor
    Don hangs out on weekends at my buddy Charlie's garage. That's my grandson he loves Don's car.
    Sent from my SAMSUNG-SM-G890A using The H.A.M.B. mobile app
    The37Kid likes this.
  28. typo41
    typo41
    So the set I saw on a shelf are an original
  29. flatheadkid1
    flatheadkid1
    from OHIO
    The intake and exhaust valves are at approximately 47.5 degrees and 40 degrees respectively.
    The engine in Lattin's Victoria is completely original and came from the Doug King collection.
    Many original parts existed which led Jim to make exact patterns for the heads themselves so the remaining original parts could be used. He cast the heads in aluminum as opposed to the original cast iron examples. To my knowledge only 3 pairs of aluminum heads were cast before the patterns were modified extensively for use on Jim's lakes car. The lakes car ran approximately 182 MPH. The patterns had to be modified because the original ports are poor.
  30. RichFox
    RichFox
    Jet96, tubman and The37Kid like this.
