Technical steering wheel frusration
Discussion in 'The Hokey Ass Message Board' started by Bummer, Feb 25, 2017.
  1. Bummer
    Bummer
    Aargh!
    Chevy is close to be finished but now this stupid steering wheel / horn ring is giving me worse headache than red wine.
    It's a -54 passenger and I fear I've lost some minor parts on steering wheel assembly or I'm just being plain stupid ( don't say it).
    What am I missing here?
  2. more specific? Don't know what your missing until we know what you got.
  3. Bummer
    Bummer
    Don't know the actual names of the parts (english isn't my language) but lets try. Wheel, horn ring, spring that goes under wheel on the shaft, spring loaded thingy that goes into the hole on the wheel, metal plate with holes and plastic ring that has three holes on the sides, three screws (hopefully right lenght).
    What else? I' thinking there should be soekind of spring to keep the horn ring nit to make contact with the base (so that it is not hot all the time).
    Pictures would be most helpfull.
  4. Yes show us some pictures.
  5. Bummer
    Bummer
    WP_20170225_17_30_18_Pro.jpg picture of what I have.
  6. Bummer
    Bummer
    Does this WP_20170225_17_38_34_Pro.jpg plastic insulator belong there?
  7. treb11
    treb11
  8. Sounds to me you are using a Grant style steering wheel adapter and horn kit.
    Yes, there should be a spring about 1 3/4" in diameter, and maybe 2"tall, tapered, to keep the contact plate off the steering wheel. Sounds to me as if you have the spring in the wrong place.
    Wheel adapter that goes on the end of your steering shaft. Then the spring loaded "thingy" goes in the extra hole on the adapter, spring up, so the metal end makes contact with the bottom of the horn assembly.
    The three bolts you have should be shouldered so that they tighten the steering wheel to the adapter, but allow the "metal plate" you described to "float" loose. Then goes the spring I described, then the metal plate, metal down, plastic up. Then the cap snaps on top of all that.
    The idea is to have the "thingy" make contact with the plate that makes up the bottom of the horn assembly whenever you push it down. The spring inside holds the horn assembly away from the steering wheel until you push down and complete the circuit.
    OK, guys chime in here, I'll bet I have really confused our friend now.....
  9. raylloyd
    raylloyd
  10. Bummer
    Bummer
  11. Bummer
    Bummer
  12. raylloyd
    raylloyd
  13. Bummer
    Bummer
  14. squirrel
    the plastic ring with the three round things is very important.
    I googled an image, it's from another forum, does this help? :)
  15. Bummer
    Bummer
    What is that wheel adapter? Wht does it look like?
  16. squirrel
    I don't see any Grant stuff in your picture.
    The spring in your first picture, goes below the steering wheel.
  17. Bummer
    Bummer
    Yes! Now we are on to something. But shold that plastic insulator ring go through the holes on the ring? Will not fit, holes are too small.
  18. Bummer
    Bummer
    Yes and yes.
  19. My bad.....ignore everything I told you.
  20. squirrel
    The horn ring...show us the horn ring.
  21. Bummer
    Bummer
    Here. Because the plastic ring insylatir did not fit the holes I made new out of ordinary hardware screw stuff. It was already on it's place and works fine. Thanks.
    Problem seems to have been on wrong instructions I found in the net earlier...
    What was that forum you found that drawing? I'd like to visit it.
  22. squirrel
    chevytalk. But I found the picture using google image search.
    great idea to make those spacers, glad it works
  23. Bummer
    Bummer
    WP_20170225_20_01_15_Pro.jpg Ok, I´m also a member there, so familiar place.
    I have to admit, that my english betrayed me earlier on the this same topic and I managed to misspell a critical line.
    Oops :oops:
    Thanks again, here´s a pic of the wheel / ring attached.
    squirrel likes this.
  24. Ya get it together? Does it work right now?
  25. Bummer
    Bummer
    Yea, it's all good now. Kinda funny though. Ripped the car in parts and put it together and biggest headache is the steering wheel!
