i want to change steering wheel on my 51 merc. it has the original column with the single key slot for the wheel. question is can i fit an early wheel on the car from a 28- 48 ford or is this a different size taper? speedway has an adapter for a 28-48 ford that changes it to the 3 hole pattern but unsure if my car has same taper. anyone know for sure? thanks in advance
I have an adapter here I pulled off a 49 Merc that had a 3 bolt grant wheel on it. Wasn't my thing. If you're interested pm me and I'll dig it up for pics. Posted using the Full Custom H.A.M.B. App!
yes if you dont mind take a pic. do you know if its the speedway item? just trying to see what options i have. like the older wheels like the lincolns. dont know if the shaft is the same taper.
