The original steering wheel on my 28 phaeton needs better coating/protection to prevent moisture activated red hand syndrome. In the past I have cleaned, dried, and coated the wheel with spar urethane, but every 2 - 3 years the coating is worn or flaked away and my hands turn red again. Do you think a automotive clear coat may be a more durable coating for me? The wheel is exposed to sunlight and moisture and gets lots of use. Thanks in advance Phred
Have you tried boat builder's Epoxy? You can probably order a small sample from WEST or System 3 or some such.
I have applied automotive clear to wood with good results. Of course all the varnish etc... would nod to be removed. It would probably be a good longer term solution.
I have used hardened clear on a few wheels and it works great. If you don't have a paint gun/clear/hardener/reducer lying around, buy this. It is expensive and has no shelf life once punctured so make sure you have a couple projects prepped that you can clear. I also use it to restore a nice gloss to old license plates.
I wrapped mine with plain cotton twine, then brushed it with boiled linseed oil. It took a long time to stop being sticky, and it's gotten darker with age, but that's probably because it's real humid down here.
I have used PlastiDip on a few simple things but nothing as large as a steering wheel yet. They sell it in the big mouth cans for dipping and brushing but they also sell it in the familiar looking, spray on cans. The dip/brush stuff would be very hard to control or prevent runs on something like a steering wheel. However, the spray would be much more manageable and allow you to build up multiple thin coats. The spray stuff sets up with a soft, satin finish, not shiny like the dip. Personally, I wouldn't attempt it with the wheel in the car. I suggest spraying it laying flat on some type of lazy susan platform where you can evenly spray one face and quickly flip it over for the other side. You want to get gravity working for you to lay it down but not run, then overlap/blend it in on the two sides. You mask it just like for paint. When I knew I was going to spray more than one coat, I masked extra layers of tape and peeled off one layer for each coat to get a smoother edge. If the wheel has any dings, this could be your chance to fill 'em and smooth them out (JB Weld maybe?) The black color can pass for a well preserved, vintage look but if you're really wanting to stay with red, it's a cardinal red they have, very bright, and is going to look pretty new. You can find the spray online easy enough. Here's a shot of a B&M shift knob I did. It looked a little better a few years ago before I threw it in a box of parts and misc. junk.......
Thanks for the ideas. I'll probably sand, clean, and automotive clear coat. Might also do a cord wrap afterwards, looks cool. Phred
