Looking for a steering wheel adapter for Flaming River column. I have a 30” non-tilt roadster column and a Billet Specialties Banjo style wheel. I need a 9 hole 8/32 adapter to mount wheel. Billet Specialties and Flaming River don’t make one and can’t tell me who does. Any help would be appreciated. Thanks Update. Took Billet Specialties adapter (1967-94 GM) to the machine shop this morning and took 3/16ths from the base. Fits perfectly. Thanks for all suggestions and comments.
This work?... https://www.performanceonline.com/s...MI1vDtz6Tn5AIVj6DsCh3CxwGjEAQYAyABEgKxtfD_BwE This is for all Ididit and Flaming River columns according to the listing. If you ordered a column with a non-GM shaft size you may be out of luck. Billet parts aren't traditional by the way....
Don't know if my reply went through but try Grant I needed a special adaptor and they were the only one that made it
I'm going to assume that a 30 inch non tilt roadster column is aftermarket but the guys need to know if it has a spline or is tapered and keyed at the top.
He identified it as a Flaming river column but if he ordered something other than the late GM shaft size the options get pretty limited.... Grant makes adaptors for most everything, but theirs are all three-hole style. They do make an 'intermediate' adaptor that goes between the three-hole and the wheel but theirs seem to be five hole, not nine.
That adapter is for GM 67-94 and will not work. Fits and lines up ok but It’s to deep. Doesn’t leave enough threads to attach properly.
http://www.flamingriver.com/index.php/products/c0001/s0008/FR20113 If this doesn't work, most likely you're going to have to modify one, make one up to fit....or go with a different wheel. Oops...Steve beat me to it.
Flaming River sells steering shafts separately, maybe a swap to a different shaft may be the answer. Be worth a phone call to find out...
Can you turn some material off of the one that is too deep? or counterbore the area where the nut goes?
While hunting possible adapters this morning I saw that same comment on the Lecara 9 hole adapter on Summits site with several saying that they had to machine the adapter to make it work so I'd think that is a universal issue with that style adapter https://www.summitracing.com/oh/par...jJQ8FtLaqdCqy8MliM0Gri1G9gSwwrLhoCpg8QAvD_BwE
The problem with machining the adaptor is it usually screws up horn button fitment, particularly if you want it to function...
