Projects Steering vega box vs unisteer in a model A
Discussion in 'The Hokey Ass Message Board' started by sdluck, Feb 6, 2018.
  1. sdluck
    sdluck
    I have a 29 model full fender SBC and it is down to the frame to the frame,it need a new steering box. I am looking at options, vega box ,unisteer, or what else have you used. Thanks
  2. I've used several early F-1 boxes & Vega boxes and one unisteer,to be honest I didn't care for the unisteer. HRP
  3. Not my car, but one I found/bought for a buyer, had a unisteer. Worked well but too slow of a ratio for the "new 32" that it was in. I didn't care for it.
    lothiandon1940 likes this.
  4. Fordors
    Fordors
    Personally I would use a Vega. And I do mean either an OEM used box in good shape if you can find one, or one made by Borgeson on the original tooling and machinery.
    I would not walk across the street for a free knock-off Vega. As always price is not everything.
    sidevalve8ba likes this.
  5. iafraser39
    iafraser39
    from Warmland
    I had a after market vega box in my roadster pick up. It gave
    me lots of trouble, both in driving and keeping it in adjustment.
    I finally went with the mavel unit. It was like night and day.
    I can steer with one finger, its that light. Its a great unit. Incidentally
    my roadster is full fendered and runs a 401 buick nailhead with
    turbo 400 trans with a switch pitch.
    Doctorterry and zzford like this.
  6. sdluck
    sdluck
    I assume you mean unisteer by Mavel.
  7. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Put a Unisteer in my '31 and liked it enough to be putting one in my '32.
    zzford likes this.
  8. DDDenny
    SD
    I paid the premium for the ?Borgeson version, have heard the offshore versions are a problem.
    BTW, how's that alloy motor coming along?
  9. sdluck
    sdluck
    The Alloy motor I picked up from the guy building it had some thing not right. I took it to a guy I used to race sprint cars with and he had done some rodeck so he is going to verify what I found. He has a test run stand. I will let you know as soon as it is running.Your car is a 32 , mine is a 29 ,what oil pan and headers are you running? I am trying to get the steering and headers figured out so I can go on with the frame and put the crossmember in and clear the pedals. All info would be of help
  10. Happydaze
    Happydaze
    I think it depends.
    I know of Unisteer replacements for absolutely fucked Vega boxes that the owners are orgasmic over. But they might have been just as pleased with a new Vega?? Face it, anything would have been an improvement over what they had!
    I replaced a new, good Vega box with a Unisteer to just get the quicker ratio - there were other reasons why I couldn't achieve this with a Vega box. I'm orgasmic too! But that's just that I got steering that feels 'right' rather than slow and wrong.
    I hear tales of reduced turning circle and whilst I accept there might be a little, it's not dramatic and the benefits swamp the negatives.
    Zero bumps steer? No way (but I'm being a bit harsh)! In an occasional major droop situation (as might be experienced on LA freeways at 80mph) there's major deviation, but it's really just a wobble in an extreme situation, which is perhaps rare(?) and quite manageable. 99.999% of the tine it's absolutely wonderful!
    I'd happily use another Unisteer. But the bracket sucks in a new build - I'd work something better in than the clearly replacement arrangement. But in my current (new) build I'm using a quick ratio Vega box, so go figure!
    Chris
    05snopro440 and zzford like this.
  11. sdluck
    sdluck
    Does your oil pan have a kickout on the bottom. Mine is a moroso for a stroker SBC.
  12. I’ve used several Vega Hybrid boxes.
    No real strength to them. Short longevity.
    I have a 32 Roadster with a Unisteer. Performs flawlessly.
    Have 7,000 miles on it now. Was a good choice.
  13. This.
  14. Blues4U
    Blues4U
    from So Cal
    So side steer is not an option?
  15. sdluck
    sdluck
    As in gear box location yes if it'll clear everything I got going on
    Sent from my SM-G550T using The H.A.M.B. mobile app
  16. Blues4U
    Blues4U
    from So Cal
    check with HAMBer @NealinCA , he does some really nice rebuilds of F1 / F100 boxes, beautiful workmanship.
    There are other choices, reversed Corvair boxes, Borgeson has some Saginaw side steer boxes, check out their catalog here: http://borgeson.com/Images/100th_Catalog.pdf
    Tim likes this.
  17. Also mustang box
  18. Roothawg
    Roothawg
    I guess I am kinda dumb but what is unisteer?
  19. sdluck
    sdluck
    And bolts up to where Vega box bolts up and it's kind of a one-way steering rack
  20. I have mustang in my Roadster. It is great. 40K miles without a hiccup. AND you don't need a Panard bar to keep everything aligned.
  21. bct
    bct
  22. Roothawg
    Roothawg
    Hmmmm..... I see.
    Thanks
    bct likes this.
  23. A Boner
    A Boner
    Why use a Unisteer......is the Vega too traditional?
  24. The aftermarket Vega type box is very poor quality. The really good aftermarket
    Box is VERY expensive.
    05snopro440 likes this.
  25. Unisteer @ $299 from Speedway vs Borgeson's good Vega box @ $335 not really a big price difference for something that works without compromise and looks like it belongs on an old car.
    117harv and Fordors like this.
  26. Never drove a unisteer in an old rod. Did drive one in a '55 Chevy and it seemed a little sluggish to me.
    Vega boxes are good enough for a light car and are cheap enough new for a car that is getting rebuilt. The feel good and work real well for a cross steer. For a side steer I would go with an F-1 or first gen F100 box, easy and work well.
    For a full on '60s build I would look for a 'vair box. I think they can be had new also. I would not use the vega or the 'vair box in a heavy car.
  27. butch27
    butch27
    I'm running a F-1. Works fine
  28. Fordors
    Fordors
    I don’t know beaner, I think the Corvair is kind of an odd duck. The ears on the casting don’t lend themselves to a good looking mount and the sector shaft is short, that means it would need to mount on top, or worse, bottom of the frame for a side steer application.
    Cross steer could work but a Borgeson Vega is considerably cheaper, compared to the only Corvair clone I would trust and that is the Flaming River Corvair box at $400+.
  29. Guess time is getting away from me, the ;last time I looked at a 'vair box it was a 150 dollar item new in the box. They were a popular item in the '60s ( some reversed for side steer) and seemed to mount well enough for the era.
  30. Fordors
    Fordors
    Yeah, I get it, time slips away. My wife will often tell me it’s not 1980 any longer when I say what I used to pay for something.
    One of the worst things the new age has brought us is the ease of making a knock-off, whether it is a steering box, brake components, a distributor or whatever. To the original poster, whichever steering box you go with buy quality, don’t shop price.
    razoo lew likes this.
