Technical Steering help
Discussion in 'Traditional Hot Rods' started by Idealclassic, Mar 24, 2019.
  1. Idealclassic
    Idealclassic
    well some days are just going to good. Putting the steering wheel back on I snapped the threads right off. Any advice where to get a new (used) part so I can fix this. Also how do I fix it.
    Thank you
  2. i'm asuming you are talking about the threads on the end of the center shaft.....what column is it?
  3. BJR
    BJR
    You need to get a new/used steering shaft, you don't say what car/year so just guessing.
  4. Idealclassic
    Idealclassic
    I think it is off of a 29 model a.
  5. Idealclassic
    Idealclassic
    I honestly don’t know. Here is a picture of the steering box
  6. 19Fordy
    19Fordy
    Repair depends on several factors.
    What size threads are those?
    What type of metal is used?
    What is dia.of "through" hole and is it needed or used?
    I assume the steering wheel bolts to that round piece which
    slips over the threads and is held with a key, correct? Then the nut is screwed down to keep the steering wheel on, correct?
    The reason I ask all this is because you could thread another piece of rod and carefully TIG weld it to the broken off piece so threads match.
  7. 42merc
    42merc
    If the hole in the center of the shaft isn't used, you could tap it & use a bolt.
    Probably go to a 3/8"or 7/16" bolt with a washer. After all it's the key & taper doing all the work.
    Hnstray, RICH B and BJR like this.
  8. BJR
    BJR
    Or do the above and then drill a hole in the bolt to let the wire through.
    Hnstray likes this.
  9. Idealclassic
    Idealclassic
    I’m all new to this hot rod world and I no idea what the little tube inside the shaft is for.
    I know I can move it by grabbing on to it and pulling with vise grips pretty easily. I like your idea of tapping the inside. Might have to grind bolt head a little bit for the steering wheel center.
    Pull center tube out
    Grind the broken piece flush
    Tap it
    Bolt it with washer maybe lock washer
    How long of bolt do you think?
    Atwater Mike likes this.
  10. 19Fordy
    19Fordy
    The horn wire may run up the steering column from the bottom of the tube.
  11. Idealclassic
    Idealclassic
    Your probably right but it didn’t have a horn in the center then and I installed a button in dash. So I could just pull it
    Stogy likes this.
  12. Fordors
    Fordors
    Steering box looks like ‘32, or ‘33-‘34. There are two different sector housings, ‘32 and the ‘33-‘34 housing which is different, gaskets and small parts are the same.
    I like the tap and bolt solution, I only gave the above information in case you ever need parts to freshen it up.
    Glen E MacDonald likes this.
  13. alchemy
    alchemy
    There's no way I'd stick a bolt in the middle of that broken shaft. I value my life too much.
    Find the casting numbers on the box and post a pic of them. And some nice clear pics of all views, all sides. Somebody will be able to tell you exactly what it is and then you can get the correct part.
    If the sector shaft is square where the pitman connects, it's an A column. If there is a splined end on the sector and a large nut holds the pitman on, it's 32 and up.
    Since the column housing in your car is not stock, the shaft may be modified as well. I'd recommend taking it all apart and have it ready to compare to a replacement you might find. Maybe it is a different length.
    Through the middle of old Ford steering shafts was the headlight switch rod and horn wiring. The center of the steering wheel had a horn button, with a switch that rotated right around the button. There was a hollow rod that ran all the way to the contacts of the switch at the bottom end of the steering box. It looks like your switch stuff is missing.
  14. Fordors
    Fordors
    If the taper on the shaft is clean and not all nicked up and the steering wheel adapter is also in good shape the taper already has a good grip on holding things together. A bolt, just as well as the original nut would provide a fail safe to secure the wheel adapter. The steering shaft is relatively heavy wall and could easily be tapped, but the tube for the horn wire is not heavy enough and would need to be shortened to clear a bolt.
    The shape of the box says Early V8, not Model A. You could check casting numbers or just see how many bolts hold the box to the frame. Two bolts- it’s an A box, three and it is either ‘32 or ‘33-‘34. As far as casting numbers go, off the top of my head I think the box will have B 3550 on it. Box is same casting number for either ‘32 or ‘33-‘34, but sector castings are different at clocking of bolts and maybe machined angle where it bolts to frame.
    Bottom line is this, if it’s ‘32 then most do not like the heavy feel of the 13-1 ratio. The ‘33-‘34 has a better ratio but still not as good as say, an F1 box. Also, the worm shaft (your broken one) is one length, but IIRC ‘32 is the longest, ‘33 might by a touch shorter and ‘34 may not match ‘33??? I guess a restorer might know the lengths.
    Hnstray likes this.
  15. that aluminum tube that went through the center was attached to the head light switch lever in the center of the wheel. in the center of that was the horn button and it's corresponding wire which ran straight through the steering box. the switch lever/tube, mechanically turned the head light switch which was mounted at the bottom of the steering box and held on with a wire bail. you can see the hooks for the bail in the photo.
    stupidest set up ever.....
    Hnstray and 31Vicky with a hemi like this.
  16. Atwater Mike
    Atwater Mike
    Total bolt thread length should be 1". I think that tube ("mast") can be tapped 7/16", SAE (fine) thread. Don't tap it USS (course) as it may compromise the integrity of the end of the tube. SAE would be preferred in a steel threading op, USS in cast iron.
    Hnstray likes this.
  17. 54vicky
    54vicky
    when done tapping if you go that way have some one with a gentler touch tighten it:rolleyes:
  18. Take some better pictures of the whole assembly inside and outside of the firewall, remove the aluminum adaptor piece and see what the taper looks like.
    I am near you, I may have something laying around to take care of you.
    harpo1313 likes this.
  19. Moon50F3
    Moon50F3
    That made me laugh. I broke a lot of shit before I got that thru my thick skull
    Stogy likes this.
  20. mgtstumpy
    mgtstumpy
    Easier for my old eyes to now see. B-3550 is the number referred to by Fordors (Post #14).
    Hnstray and tb33anda3rd like this.
  21. alchemy
    alchemy
    Yep, I see the B now. Time to take the thing apart to measure the length of the shaft to make sure you get the right length shaft. And see if the ratio has been changed.
  22. I have the pieces laying to get your problem fixed, you have my number call me
