Hot Rods steering drop arm taper question
Discussion in 'The Hokey Ass Message Board' started by nifty, May 8, 2016.
  1. nifty
    nifty
    from UK
    Can anyone tell me if the taper angle of the steering arms of a 40's Ford are the same as those of a 30's Mopar?
    I need to replace the original worn out tie rod ends on the 36 Dodge double dip tube front end (replacements cost about $80 each before shipping and import duty), so i was thinking of swapping to cheaper generic Ford items.
  2. 19Eddy30
    19Eddy30
    from VA
    Go to Moog , look up your application, then go to spec chart ,
    Then you can search to see that tapper ,
  3. alchemy
    alchemy
    I don't know about the Moparts, but the Fords are 7 degrees taper.
  4. thirtytwo
    thirtytwo
    The threads on the 35 and up tie rod ends are also 11/16 so that might be a bit of an oddity also ...most I believe are 5/8
  5. nifty
    nifty
    from UK
    Thanks for the help guys
