Steadfast 1928-1929 Ford Model A Pickup Truck Hot Rod, Street Rod,
Discussion in 'Cars For Sale' started by Steadfast mfg, Dec 29, 2018.
  1. Steadfast mfg
    Steadfast mfg
    City: Mansfield
    State: Ohio
    Price: 22,500.00
    Here is your chance to own a truck that will demand attention when you roll into any NSRA or Goodguys show!
    I personally don't want to waste my time building a Hot Rod that wont get attention and neither should you! I want something to sit right, looks right and demands everyone's attention!
    Since not everyone can get that perfect stance and use the right combo of parts, I am making it easy by setting it up for you. For just a little over the price of whats included!
    YOU can make this Steadfast truck all YOURS by setting it up with YOUR COLOR of choice, YOUR MOTOR & TRANSMISSION combo and YOUR INTERIOR color & style!
    One thing you will notice is how low it sits. This truck is 100% drive-able at this ride height. We custom order the axles narrow and have a spring custom made to accommodate the narrow axle. The narrow axle allows for lock to lock turning without the tires rubbing the fender!
    The rear cross-member is set up to house a heavy Johnsons Hot Rod Shop rear sway bar (not included) that helps eliminate body roll. This way you don't have to worry about the tires rubbing the fender around an 80 mph entrance/exit ramp!
    48374249_799467783727437_4981587650138865664_n.jpg 48380931_327244641200208_2536787867485601792_n.jpg 48385471_2366350333395038_1318893862856425472_n.jpg 48385871_1143557412488814_7806179661221724160_n.jpg 48386143_332908357438205_3206744328336572416_n.jpg 48394617_369794300244386_6476476619811717120_n.jpg 48395050_727929937591961_797179907623878656_n.jpg 48398027_213519596196659_1950069384659599360_n.jpg 48406753_2206340109416905_240819653805342720_n.jpg 48410935_224120558501749_4340966361380421632_n.jpg 48411188_321359968465579_8096478845810507776_n.jpg 48411300_372489486819536_3909514150350422016_n.jpg 48394812_295210454446210_9208308005999738880_n.jpg
    If you have any questions regarding this truck feel free to contact Henry at Steadfast Mfg and ask away!
    Here's a list of what you get....
    • Steadfast A-Truck Chassis $3,250.00
      • (Motor/trans mount NOT INCLUDED that way your options are open)
    Front:
    • Custom Front Axle 472.00
    • Front Spring 231.00
    • Custom Spring Plate 50.00
    • Shackles 50.00
    • Adjustable Perches 146.00
    • Lower Shock Mounts 72.00
    • Hairpin Kit 397.00
    • Spindles, Bushings, King Pin 265.00
    • Spindle Nuts 16.00
    • Steering Arms 94.00
    • Steering Box Mount 50.00
    • Borgesn Vega Box 379.00
    • Tie Rod 85.00
    • Drag Link 81.00
    • Front Panhard 114.00
    • Basic Disc Brake Set 395.00
    • So~Cal Pitman Arm 79.00
    • So~ Cal Hooded Shocks 75.00
    Rear:
    • New Johns Ind. 9 in. w/31 Spline Axles 869.00
    • Ladder Bar kit 455.00
    • Steadfast Bracket kit 180.00
    • Shackles 50.00
    • Posies Spring 295.00
    • So~Cal Shocks 75.00
    • So~Cal F1-Rear Shock Mounts 131.00
    • Set up for/ but not included Johnsons Hot Rod Shop Rear Sway Bar 479.00
    Body In Fresh Black Primer:
    • Super Nice ,29 Pickup Cab (FoMoCo) 5,340.00
      • (the cab is very nice, except for the drivers door. Door can be fixed or replaced, call for details. Firewall has been recessed)
    • New Brookville Bed 1,675.00
    • New Brookville Fenders, Running Boards & Brace Kit 2,250.00
    • Dropped Head Light Bar 123.00
    • New Grille Shell 160.00
    • All New Wood Kit - lightly tacked in 725.00
    • Nice Original Hood 580.00
    American Rebal Wheels & Firestone Tires: 2,525.00
    • Fronts 15 x 4.5 ~ 135/15
    • Rears 16 x 8 ~ P255/70R16
    Miscellaneous Parts:
    • Wood
    • Screws
    • etc.
    Note: Parts are Pete & Jakes unless noted otherwise
    Located in the middle of Ohio, USA!
    Delivery available, message us with your zip code for delivery fee quote.
    Steadfast Manufacturing specializes in custom hot rod fabrication and product design. We manufacture and sell our own products that are designed and built in our own facility. None of our products are manufactured outside the USA.
    Additionally, we are authorized sellers of high-quality hot rod and performance parts from Pete and Jake*s, Perfection Hot Rod Parts by Johnson's Hot Rod Shop, Brookville Roadster, John*s Industries 9 Inch Factory, Vintage Air and LimeWorks, just to name a few.
    Follow us on Facebook or Instagram: at steadfastmfg
  2. Steadfast mfg
    Steadfast mfg
  3. Steadfast mfg
    Steadfast mfg
  4. Steadfast mfg
    Steadfast mfg
  5. Steadfast mfg
    Steadfast mfg
    SOLD Headed to TEXAS!
    Cyclone Kevin likes this.
