Projects Starting a 28-29 Model A Roadster build for the kids
Discussion in 'Traditional Hot Rods' started by 13clicks, May 10, 2018.
  1. 13clicks
    13clicks
    Looking for a schematic for there wood blocks on my 28-29 roadster. Anyone????
    55Deso likes this.
  2. sloppy jalopies
    sloppy jalopies
    Those are not or not all the '28-'29 roadster body blocks...
    there is a post here on '30-'31 body blocks... '28-'29 ?
    front '28-'29 block has 3 cowl bolts go through it...
  3. 13clicks
    13clicks
    Ohhhh haha yeah I’ve got the front ones installed because they were easy and straight forward fitting. I’m just looking for a layout for the rest of them. Thanks
  4. alchemy
    alchemy
    Well I do know the smallest ones go over the rear crossmember.
  5. 13clicks
    13clicks
    Yay that is a start.... thanks! I might be able to figure out the rest. I just hop I get them all in the correct orientation.
  6. alchemy
    alchemy
    It should be easy. Just watch where the cutouts and thin spots are, they usually are clearanced out for a double layer of metal on the underside of the subrail, or some other obstruction (rivets?).
    13clicks likes this.
  7. Aaron D.
    Aaron D.
    Hope this helps.
  8. 13clicks
    13clicks
    Yesssssss that’s it!!!! Thank you very much Aaron!!!!!
    Aaron D. likes this.
  9. 13clicks
    13clicks
    Just getting this shit to fit... I’ve never done exhaust or anything with tubing. I’m waiting on some more bends to come in the mail to finish it up. IMG_2310.JPG
    Mikel50 likes this.
  10. 13clicks
    13clicks
    First layer of rust off... shoulders and arms tired.
    Outback and Mikel50 like this.
  11. sloppy jalopies
    sloppy jalopies
    the tightest 90*s I have ever seen are the ends of a commercial building's stairway handrails...
    much thicker gauge and are stamped, needs the seam welded [easy its thick]...
    because they are thick, you could cut them down to a 45* or whatever and weld them... HIH.
  12. Definitely gotta subscribe to this thread! You plan on going to the Santa Margarita FAST event July 7th?
  13. 13clicks
    13clicks
    Probably not going to make the 7th but will be at the FAST one in the fall. Maybe my cousins roadster will be at the 7th. Thanks for subscribing.
  14. No problem! Always gotta love a good build thread. I'll probably be there at the fall one!
  15. How in the F do I change my name? Hey Cuz!
  16. Outback
    Outback
    from NE Vic
    As cool as a cool thing!
    I've got an RPU on the back burner, have sub'd!
  17. 13clicks
    13clicks
    55Deso and ROCKER77 like this.
  18. ChoppaScott
    ChoppaScott
    Just curious. Have you added a heat shield to those headers or is it just the angle the pic is taken from. Watched your video as I'm about to tackle the same job. Nice work!
    Sent from my Pixel XL using The H.A.M.B. mobile app
  19. 13clicks
    13clicks
    I don’t know what heat shields are hahha soo I’m guessing I didn’t use any.
    It’s not hard... just takes time... three times measuring 1 time cut.
    Please explain heat shields. Thanks.
  20. 13clicks
    13clicks
    Yeah dude!!!! I don’t know. Check the help thread.
  21. 13clicks
    13clicks
    Header complete. Now it’s on to wiring and 12volt conversation.
  22. neds29
    neds29
    You need a '28- '29 radiator shell! Nice project though. Ned
