ok ive got a 96 5.0 with a m5r2 manual trans and a new starter , it just hits on the flywheel doesnt turn it over , 3rd starter that did this ???????
To go along with what Hotroddon said above check this and it may clear things up http://www.bcbroncos.com/ford starters.pdf
If it came out of a red car it's a different starter than a blue car. If it was finished after May 31st a different starter than before. F O R D Finished on right day
Small block Fords have 2 different starters, one for automatic transmissions and the other for manual. The trick is that all 157 tooth flywheels use automatic transmission starters regardless of the transmission installed. Yeah, don't ask. Fords don't use shims, except there is a spacer shim available if your crankshaft thrust bearing is worn out enough to relocate your flywheel. If you need one of those, you have bigger problems. There is also another way to screw up a Ford build, and that is to install a 157 tooth flywheel in a 164 tooth bellhousing.
