Technical Starter Help Buick Straight 8
Discussion in 'The Hokey Ass Message Board' started by 1941g506, Aug 29, 2021.
  1. 1941g506
    1941g506
    Ok, so I have a 1940 model buick straight 8 engine I bought as a spare. Motor is complete. I have two separate starters. I am trying eitjier starter with 12 volts, no other vehicle electronics hooked up. From what I read the starter can handle the 12 no issues. When I try these starters outside of the vehicle (testing with jumper cables) they function flawlessly. When on the car both starters will barley crank the engine when the bendix is engaged. I thought maybe the engine may be tight or trying to lock up, but the engine has no belts currently and can be turned by hand fairly easily. Thanks!
  2. Rickybop
    Rickybop
    You have the same problem with both starters, so I doubt that they're the problem.
    Did you paint the mating surface between the starter and the bellhousing? Possibly affecting getting a good ground?
    Hnstray likes this.
  3. 1941g506
    1941g506
    Quite possibly I thought about that, it's probably not getting a very good connection regardless using jumper cables.
  4. squirrel
    Jumper cables won't work for that, you need battery cables. And heavy ones...
    Hnstray likes this.
  5. Rickybop
    Rickybop
  6. 1941g506
    1941g506
    Thanks guys makes since I'm young and never had anyone really show me how to work on anything so it's trial and error.
    Budget36 and TrailerTrashToo like this.
  7. Maybe check to make sure you have a good ground - maybe run one to the frame to the motor and of course to the motor - I've missed that myself.
  8. Ebbsspeed
    Ebbsspeed
    @1941g506 Where are you in East Tennessee? I spent some time out there in the 1970's. Nice country.
  9. 1941g506
    1941g506
    Near Johnson city, Kingsport area. Thanks guys
  10. You may want to pull the valve cover and check how quickly the valves close. Turning the engine over by hand allows time for valves sticking in the guides to slowly close. There might be one or two sticking enough to cause slight interference when cranking with the starter. I do agree with Squirrel, use heavy cables.
  11. Stooge
    Stooge
    There were also different starters, (atleast with additional windings) for the differently sized straight 8s, and where a starter for a Special, might be slow to turn over a bigger engined Century or Roadmaster. But, like Squirrel said, thick battery and ground cables and a battery should yield some results
  12. Larger cables, as 0000, if possible. They will be as large as your thumb or larger. Local parts store probably does not have them.
    If using 12V, parts store cables will probably work. They are probably 2GA, the jumpers are probably 6 or smaller.
    Ben
  13. squirrel
    2 gauge would probably work fine. 00 definitely is big enough.
  14. 1941g506
    1941g506
    Thanks guys! She fired right up when using the heavy cables.
    Stooge, squirrel and TrailerTrashToo like this.
  15. Rickybop
    Rickybop
  16. Guy Patterson
    Guy Patterson
    Bet those jumper cables were getting hot as hell
    1941g506 likes this.
