Projects Start to my 34 PU project
Discussion in 'Traditional Hot Rods' started by Dustan, Apr 6, 2016.
  1. Dustan
    Dustan
    from PNW
    Last weekend at a big local swapmeet I ended up finding me a really nice 34 Ford cab. I love these trucks so I had to have it. I'm busy trying to finish up a model a Tudor sedan on a 32 chassis at the moment but as soon as that's finished I'm starting my truck Shooting for around September to start this one. I'm pretty excited to start this one. I'm thinking I want to use a 32 frame,grill/shell,and 32 bed to match the frame. Probably going to go fenderless with wires and just a hood top with lake pipes. Haven't decided if I want to chop this one yet but if I do it will only be 3"
    Capt Chap likes this.
  2. Nobey
    Nobey
    Really nice cab you have there, why not build a 34 pickup?
  3. That cab looks solid as a rock! Congratulations on your score.
    Dustan likes this.
  4. Papas32
    Papas32
    from No.Ia.
    wish mine was that solid!
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Great looking cab. I too was lucky enough to have a good starter. Fenders are the new wave. Those pickups look much better with running boards and fenders. More complete. I will donate the first left rear fender for free. How about that???
    Dustan likes this.
  6. dumprat
    dumprat
    from b.c.
    Build it as a 34. Way nicer grill than a 32 car grille stuck where it doesn't belong.
  7. Dustan
    Dustan
    from PNW
    It will be a 34 pickup. Just on a 32 frame and bed haha. The main reason is because I want it fenderless and I like the look of the 32 frame with the reveal a lot better.
    1927graham likes this.
  8. Dustan
    Dustan
    from PNW
    The cab is really nice and solid. My plans might change before I start. Who knows I have a few months before I do anything.
  9. Dustan
    Dustan
    from PNW
    The cab is very solid. There is a small hole in the driver lower cowl and the door bottoms are pretty much gone. But that's pretty much the worst of it. Subrails look great.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    I too like the 32 frame. But I love the swoopy lines of the 34 fenders much better.
  11. Dustan
    Dustan
    from PNW
    Yep,I agree. I'm planning fenderless so that's what made me think 32. Might still use the 34 grille though. I think the 33-4 frame and bed was also about 6" longer too. That's why I said 32 bed. But I could just shorten a 34 too.
    Petejoe likes this.
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    32-34 beds are all the same length...71"
    Moriarity likes this.
  13. Dustan
    Dustan
    from PNW
    Okay so it was just the frame then? Good to know.
  14. 3wLarry
    3wLarry
    from Owasso, Ok
    32 wheelbase...106"
    33/34 wheelbase 112"
    all ford beds from 32-37 were 71"x46"
    Moriarity and Dustan like this.
  15. Just to clarify here....
    The '32 bedside has a rolled seam to match the placement of the rear fender. It is forward of the rolled seam on the '33-'34 pickup bed. So if you use the early bed on a '32 frame with the stock wheelbase, your rear tire will be centered properly on the fender reveal surround.
    If you try and set up for a '32 frame and wheelbase- but you have a '33-34 bed- your tire will not be centered on the bedside roll. The roll will be too far rearward of your tire.
    A simple way to identify the two different beds is to note that the distance on a stocked fendered pickup between the front of the bed and the front of the rear fnder. It is much shorter on a '32 than on a '33-34.
    Dustan likes this.
  16. Dustan
    Dustan
    from PNW
    Thanks for the info. I don't know a whole lot about these trucks yet.
  17. Dustan
    Dustan
    from PNW
    Does anyone know of a stock looking reproduction 32 bed? I can't seem to find anything. What I can find is smooth sided beds and I would much rather have the rolled seams.
  18. It's a good time to stop and really think about your build before you go any further. My big question would be, Do you think you'll ever want to add fenders somewhere down the road? If you do, that takes you in one direction only. If you always want to stay fenderless, there are many other possibilities.
    One place to start is looking through pics of other fenderless trucks. Nothing says you have to stick with the OEM Ford bed for your model year. There are a number of truck threads here on the HAMB. I'd do some research.
    Here are two of my fenderless favorites:
  19. Dustan
    Dustan
    from PNW
    image.jpeg Yep,I will stay fenderless. If I want fenders I will build another one. I'm not really a fender kind of guy ;) 32 frame 32 box shortened to 58-60". I like building stuff this will be my 3rd one in just over a year. Need to finish up the A first though. Just a few more months. In the meantime I will be gathering parts for the 34. Here's a pic of the A im doing.
  20. Toast
    Toast
    from Jenks, OK
    nice cab! I do like mine with fenders though.
    Roger53 and Dustan like this.
  21. Dustan
    Dustan
    from PNW
    Your truck does look good. How long is that bed?
  22. Toast
    Toast
    from Jenks, OK
    Thanks, As I remember it is 64" long
    Dustan likes this.
  23. embyman68
    embyman68
    From another thread...(No guarantee that this is accurate, however,
    We put a 36 bed on my dads 37 and it was definitely shorter than the 37 bed)
    35, 36 are the same
    37 is 4'' longer and has a rail support just above the center of the fender under the side rail of the bed.
    38-41 ar the same and then the 42-47 get 3' wider
    Dustan likes this.
  24. waxhead
    waxhead
    from West Oz
    Cool, another pickup build. I will be watching.
  25. Petejoe
    Petejoe
    from Zoar, Ohio
    I too like to see fender less on coupes and sedans. To me it's just something about seeing an exposed square bed without fenders on early trucks that gives an unfinished look. Have fun with your project. There's always another time as you suggested.
  26. Roger53
    Roger53
    WOW what a nice cab to start your build! Roger
    Dustan likes this.
  27. Dustan: I had this one a few years back. It's a '32 frame, '34 cab with a 35-36 bed shortened in front of the wheel, eliminating the stake pocket. Tim 100_0004.JPG 100_0103.JPG 100_0106.JPG
  28. Dustan
    Dustan
    from PNW
  29. gordspeed
    gordspeed
    from Oregon
    Nice Cab! The Sedan is looking good too! :)
    Dustan likes this.
  30. I don't recall what the length was but I cut 11" out of it, I do remember that.
    Dustan likes this.
