SOLD Beautifully polished stainless steel engine turned dash with a set of Stewart Warner gauges. Dash is 11" long by 5 1/4" tall at its center. Center hole is 3 3/8" and will fit a standard tachometer or speedometer. Center hole left open so you can choose the gauge you want to use. Has a working red jewel light and toggle switch. 4 brass mounting screws at the corners. Stewart Warner Mechanical Water Temp gauge. (S.W. 835662) Has the coffin needle and is a deluxe gauge with the light window around the case for illumination. Light bulb kit included with purchase. Gauge has never been used, removed from original package and installed. Gauge looks great and preforms as it should. Stewart Warner 2 1/16" Mechanical Oil Pressure gauge. (S.W. 835661) Has the coffin needle and is a deluxe gauge with the light window around the case for illumination. Light bulb kit included with purchase. Also included is the oil line and fittings for installation. Gauge has never been used, removed from original package and installed. Gauge looks and preforms great. Stewart Warner 2 1/16" AMPS gauge (S.W. 827477). Has the coffin needle and is a deluxe gauge with the light window around the case for illumination. Light bulb kit included with purchase. Gauge has never been installed, removed from original package and placed in this panel. Gauge looks and preforms great. AC Fuel Gauge. 2 1/16", (12 Volt). Step bezel with light port in the rear of the case allowing for illumination. Glass is very clear and in great condition with no scratches or chips. Bezel shines very nice with no dings, chips or tweaks. I put power to the gauge the needle moves from F to E and back to F.
