stainless bolts for exhaust manifold?
Discussion in 'The Hokey Ass Message Board' started by scotty t, May 19, 2012.
  1. will i have any issues using stainless bolts for my exhaust manifolds on my 348 chevy? a buddy says not to use them he says they won't stay tight. something about expansion rates?
    thanks
  2. gimpyshotrods
    gimpyshotrods
    I have been using them for a few decades. No problems with them staying tight. Maybe I'm doing it wrong.
  3. Special Ed
    Special Ed
    You should check, and (possibly) re-tighten them after a few hot/cold cycles. But you'd have to do that with any kind of bolt. Listen to Gimpy.
    Oh yeah... use a little anti-seize, too.
  4. bbfmavrick
    bbfmavrick
    Definately:)
  5. seb fontana
    seb fontana
    from ct
    Me too!!
  6. gimpyshotrods
    gimpyshotrods
    Yeah, that too. It is such a regular part of my routine, that I forget to mention it.
  7. thanks guys, stainless bolts installed.
  8. lakeroadster
    lakeroadster
    from *
    Stainless has a higher "thermal expansion rate" than steel. Basically that means that as the steel manifold and stainless bolts heats up, the manifold to head gasket loading decreases due to using stainless bolts.
    It's hard to argue though with folks that have actually used stainless bolts with success.
    Sometimes the laws of physics don't amount to shit if they are trumped by actual experience :D
  9. Throw a lock washer under them and motor on. I see no problem using them.
    Bob
  10. langy
    langy
    I've used them for around the last 40 years, never been a problem for me.
    ARP make and sell stainless header bolts, I guess they dont know :)
  11. marioD
    marioD
    works fine if you use some coppergrease on the bolts and retighten frequently...
    Mario
