Spring in front of axle front suspension?
Discussion in 'The Hokey Ass Message Board' started by dsiddons, Oct 25, 2011.
  1. dsiddons
    dsiddons
    from Indiana
    Seems to be alot of 37'ish front axle assemblies out there to be had. (ive seen three recently) I was wondering if anyone setup their Hot Rod with one of these type of front axles?
  2. Dreddybear
    Dreddybear
    The Khougaz Roadster is spring-in-front. And I hold that to be one of the baddest cars around..
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Many old hotrods were built with 35-48 spring in front suspensions. A few are being built this way today. Nothing is new except that Ford suspension in 1935... then it was old.
  4. dsiddons
    dsiddons
    from Indiana
    Don Ferrara's roadster is one of my all time favorite. I'll have to search the Khougaz roadster.
  5. el Scotto
    el Scotto
    from Tracy, CA
    I love this one!!
  6. flatheadpete
    flatheadpete
    from Burton, MI
    100%!! Khougaz was is and will always be one of the coolest....and I normally hate channelled Deuce roadsters.
  7. dsiddons
    dsiddons
    from Indiana
    I like this idea. But I need that crossmember free for the radiator and grill shell. Is that a 40 or 41' axle?
  8. MikeRose
    MikeRose
  9. dsiddons
    dsiddons
    from Indiana
    So what's the best year axle assembly to use?
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    Anything from 37-48 will pretty much be similar. One thing to remember though is that doing this shortens the WB by about 6 inches unless you move the perch out further.
    Don
  11. Dreddybear
    Dreddybear
    Here's a good shot of the front of the Khougaz car..
  12. Dreddybear
    Dreddybear
    This bitchin coupe has it too..
  13. chopper cliff
    chopper cliff
    from lodi ca
    some turn them around and use them as spring hangers in the rear, after you whack off the wishbone and shape it a little it actually look's good, Ivo did it and I have seen it on several cars, mostly buckets
  14. dana barlow
    dana barlow
    from Miami Fla.
    I made my own shackles and used the modal A spring back in the late 50's,but ya.
    she was power by 292Y-block ford,I was working on motor at photo time.
    yes it is a bobtailed 28 roadster
    dsiddons likes this.
  15. porknbeaner
    porknbeaner
    I think one of the things that we miss in our modern build mind set is that with the pring in front of the axle you can adjust the ride height slightly by lengthing the shackles like on a boat fender foad with the spring behind the rear axle.
    I also like the look if the axle being slid back a bit because of the set up it makes the grill shell look like you moved it forward. Changes the whole profile without really changing anything but the suspension.
    Scotto,
    Love the bucket BTW. it could use a little paint by my way of thinking but if you give it a good hard look it has a lot going on besides the front suspension. Friend of yours or just a pic you snagged at a show?
  16. Harms Way
    Harms Way
  17. Ned Ludd
    Ned Ludd
    X2 ... and I normally hate grille shells relocated forwards.
  18. chopt top kid
    chopt top kid
    I think they look fine as long as you're putting them under a '35-'48 ford...:rolleyes:
  19. richie rebel
    richie rebel
    the spring in front is call a suicide front end,not that theirs any thing wrong with it......
  20. Dreddybear
    Dreddybear
    That's when the spring is hanging out there all by itself with a mount that, if it breaks, has nothing to stop the car from plowing. These are all examples of factory ford type spring-behind setups..
  21. No it is not. A suicide front end is one w/o frame horns to catch things if the spring breaks, spring in front CAN be but isn't ALWAYS suicide. :rolleyes:
  22. Dreddybear
    Dreddybear
    I don't think the grille shell is pushed forward, that's an illusion due to the decreased wheelbase of the spring behind setup. In person this car has spot on proportions.
  23. bgaro
    bgaro
    mine is setup simular to this, but the spring is mounted under the A crossmember instead of a suicide perch. it frees up room for a shell and the rad sits ontop of the cross member.
  24. Im going to have to give this set-up another look.
    I need to move my crossmember forward to gain some blower pulley room. That's increasing my wheel base and I'm not crazy about it.
    This will probably will push my grille too far past the tires and then I won't like that. Uughhh
    On another note
    Id like to see a pic of a spring behind that is not suicide style, and a pic of a spring in front that is suicide style.
  25. Crankhole
    Crankhole
    Let's not forget the Isky T...
  26. Don's Hot Rods
    Don's Hot Rods
    from florida
    Well, it does sort of move the radiator visually forward somewhat because if you mount the spring directly under the radiator it has to move the axle centerline back 6 inches. The cars that were shown with the spring in front sure don't look bad though, although most people say to look right the axle centerline should be directly in line with the radiator. Guess that is what makes hot rodding hot rodding, even the rules can sometimes be ignored and the results can be spectacular. :)
    Don
  27. Ned Ludd
    Ned Ludd
    The axle is moved back in relation to the grille shell, which is almost the same as moving the shell forwards and then shortening the frame the same amount. That's what I usually don't like, but this one looks good. I think it's the frame-horn fairing that ties everything together.
  28. dana barlow
    dana barlow
    from Miami Fla.
    From 1959 too now,this one has always had 1948 front set up,the spring is less leafs an revers eye,but front of axles. Powered by Y-Block Ford Thunderbird
    tfeverfred likes this.
