Spray on Chrome..
Discussion in 'The Hokey Ass Message Board' started by IrishHills, Oct 28, 2010.
  1. nicamarvin
    nicamarvin
    from nicaragua
    another simple set up
    instead of using a stand alone rinsing spray gun, a water hose its used
    instead of using a dedicated sensitizing spray gun, a plastic hand sprayer its used
    http://www.youtube.com/watch?v=XVcu57xN538
    Simple uh? :D now protecting the Silvered part its the tricky part...:eek:
  2. prolab coatings
    prolab coatings
    from England
    Hello everyone.! I thought I would share my knowledge in this subject as I have 8 years experience actually doing the spray on chrome proccess.
    First of all what you have to realise is that there is no spray on chrome there is no such thing. You are spraying silver nitrate. Second of all this is not a paint application it is a chemical application and you are appying a reaction of silver onto the basecoated part so you are trying to controll a chemicall reaction as it happens in front of you.
    here are a few tips n tricks i do to make this proccess easy and i mean easy.
    step 1 basecoat all parts 24 hours before silvering to make sure your basecoat is 100% dry.
    step 2 when mixing your chemicals be sure to mix the sensitizer 30 mins before the other chemicals this ensures that the tin has bonded to the water molecules properly and will there fore wet the surface for longer.
    step 3 if your chemical is reacting too fast for your liking half the chemical mix not the water. this will slow down the reaction time and the deposition of the silver making it more controlable. Dont forget your controlling a reaction this reaction is called (autocatalyst) read up on Brashears proccess and tollens theorys.
    I hope this all helps if you have any questions post me.
  3. M.Edell
    M.Edell
    My Grille,Windshield Frame and pitman arm all all spray chromed [​IMG]
  4. CDXXVII
    CDXXVII
    from Vermont
    Thanks prolab for the clarifications. Have you ever tried this process on old thermoplastic injection molded interior parts? I have some Ford armrest bases that were vacuum metalized in the 1960's. I am wondering if this nitrate would be a better restoration option than the vacuum metalizing.
  5. bobj49f2
    bobj49f2
    Have you had this car out on the road for an extended period of time yet? I'd be interested in seeing how it holds up under normal road conditions.
  6. dabirdguy
    dabirdguy
    I have a pair of '53 Buick headlight bezels that were started down the road on this processes when the company went belly-up. They are primed and ready for the final coatings. Anybody up to finishing them?
  7. Tim G
    Tim G
    Where you based in England?
  8. Imperial Kustom
    Imperial Kustom
    I have had a few companies send me their swag on this since I am thinking about offeri.g it at my shop. it seems to be nearly the same process as silvering mirrors.
  9. bulldogcustomchrome
    bulldogcustomchrome
    Cosmichrome has the highest heat rating at 350 degrees.
  10. Normbc9
    Normbc9
    In the Sacramento, CA area there is a shop of South watt Avenue that does this type of work exclusively. Their finished product looks great. They did a valve cover and a set of headers for me. Good work, reasonable prices and one year later with daily use no complaints.
    Norrmbc9
  11. I can't wait for the low buck solution to this process! Drag racers will be lined up around the block to get their fiberglass bumpers done. One of many huge markets for this process.
  12. hupster
    hupster
    from california
    What's the name of the place in Sacramento?
  13. bulldogcustomchrome
    bulldogcustomchrome
    I'd be glad to help you out with the headlight bezels.PM me or email- shane@bulldogcustomchrome.com
  14. fryguy
    fryguy
    Glen, not following you on this. 53 buick bezels are stainless and you just have to polish them up. 54 buick bezels are potmetal. Those would probably work.
    Fryguy
  15. Cutlassboy68
    Cutlassboy68
    from Boone, Nc
    I use it time to time. Works good, doesnt really look like chrome but more like polished aluminium. IMO
  16. M.Edell
    M.Edell
  17. dabirdguy
    dabirdguy
    These are the ones i have:
    This is a pic of one of the ones I sent them before I sent it.
    It is now in a gray primer. Looks flawless, but in primer.
  18. fryguy
    fryguy
    Yep, glen those are 54 buick bezels. They are potmetal so you wouldhave to rechrome or alternative chromethem. Thanks for the pic.
    Fryguy
  19. nicamarvin
    nicamarvin
    from nicaragua
    watch below link for future Updates... ;)
    http://cs.scaleautomag.com/SCACS/forums/t/106523.aspx
  20. h2omonkey
    h2omonkey
    from vegas
    Just read through this thread and the problem seems to be the final clear coating over the silvering process. A few pages back someone mentioned clear powder coating but no one ever responded, has anyone tried an industrial strength clear powder coat? Many are made specifically to prevent fading and to not yellow.
  21. nicamarvin
    nicamarvin
    from nicaragua
    well it was me, I had the idea of Clear Powder coat over the silvered surface. an nobody has tried yet. it will be up to me to do it I guess.. I ordered Liquid Powder from Caswell plating. it should allow me to spray it over a plastic surface then, slowly bake the powder(will not fully cure due to low heat).. I will be also testing it over metal piece
  22. leaded
    leaded
    from Norway
    Waiting to hear how it did go...!
    Clear powder is great, and strong enough to keep up against the environment,
    trouble is that it could chip by som small stones/gravel. And, of course the sulotion by heating to cure it! Normal paint woudnt hold up, and dont it uses quite normal similar ones at the "primer"?.. Perhaps try some preheating of the part primed to outgas , let cool, before powder it.....
    Try it, nobody will know before someone had done it!:cool:
  23. nicamarvin
    nicamarvin
    from nicaragua
    nothing yet..:mad: been having lots of issues with UPS delivering my package to my shipping company..
  24. 54Lark
    54Lark
    Marvin, I just want to tell you I really admire your tenacity, hope you will find all of the ansers you are looking for. I have owned a 54 buick skylark with really bad potmetal parts (fins, head light bazels etc.) and have been looking for a system that I can use to repair these parts. Please keep us up to date with what ever you find.
  25. Does anyone know of a shop on the gulf coast?
  26. Shopking
    Shopking
    from central Pa
    I do a lot of gas pump restorations ,some have a lot of pitted brightwork.Im going to look into this rather than sending everything out to the chrome shop.
  27. nicamarvin
    nicamarvin
    from nicaragua
    Just wait for a few more days...:cool: the Packages just arrived to Nicaragua, I need a few more days for the long customs paper work...:mad:
    coming soon...
    Alsa Chrome FX(small Pump system, same chemicals) vs Off the Shelf counter part
    vs
    Also I will also use a drip method(instead of spraying it)
    I got a few items for Caswell plating(Ultra Chrome Powder coat, Liquid Powder, Cerakote Chromex ceramic coating) and a CopyChrome Plug and Plate kit. I will try to plate over a silvered surface(using the spray on chrome/silver systems)
    the spoon on the pic was silvered, at the time I did not have the plug and plate kit)
    I also ordered an small sample of Innate Chrome paint. I´ll be using their special clear to see how well it does perform
    all in all I´ll be very bussy testing all of this chrome like products, I´ll be posting pics as I get them... wish me luck
  28. 54Lark
    54Lark
    I checked Pchrome's web site and it syas "just as hard, just as durable as real chrome" I find it hard to beleive that any sprayon top coat can be as hard as real chrome. (real chrome 1000. on the rockwell scale). In the sales world this is called puffing, in my world it's called bull shit!
    Now I'm not knocking spray on chrome, in fact I am very interested in it, but let's stay honest here.
    It looks to me that they are more interested in selling instruction $5000.00, wow, for a 2 day coarse than any thing else.
  29. nicamarvin
    nicamarvin
    from nicaragua
    Yeah I have checked their website before...
  30. Gambo
    Gambo
    I have read through most of the post on this thread and can understand the confusion about spray on chrome. In general it works some time but not at others. 3 years ago I was asked to research the problem by a company that had purchased the UK rights too one of the systems but could not get it to work. After a good deal of work we built a system which worked every time but the commissioning company had financial problems due to another project and went bust. Our system has now been revived astrachrome.co.uk take a look I think you will find it interesting also see Gammascience.co.uk Story of a project
