Spray gun problems
Discussion in 'The Hokey Ass Message Board' started by fred56, Sep 10, 2009.
  1. fred56
    fred56
    I went to spray on Black lacquer paint with a Sharpe 998 Siphon feed HVLP gun(I know buy a regular HVLP) and at first it sprayed on nice and the more I painted the paint started to dry gray looking and no matter what I adjusted the results were the same.
    Does anyone have an idea what I am doing wrong?
    Jerry
  2. lippy
    lippy
    from Ks
    Maybe humidity? Retarder or slower reducer. I can't see how the gun could have any effect on the color change.Make sure your not getting oil or moisture out of the line also. Lippy
  3. Rick Sis
    Rick Sis
    from Tulsa OK
    Been getting some rain in Ohio? As Lippy said, the description does sound like it's blushing from humidity. Always best to watch the weather and wait for dry conditions when spraying lacquer. Your Sharpe gun should work fine.
  4. skullhat
    skullhat
    get some slower thinner and retarder in there and try again.
    if you air cap and or fluid nozzle are clogged, the dry overspray produced can give a whiteish or gray appearance
    with lacquer you need`to clean your nozzle and cap more frequently
    skull
  5. fred56
    fred56
    Thanks for the fast answers, due to the current weather it sounds like you have a handle on my problem.
    Thanks - Jerry
    P.S. I just checked the gun and found that the air breather hose to the cup was blocked. That couls also have caused the dry overspray.
    Thanks again.
  6. skullhat
    skullhat
    that will do it, they make your gun run "lean"
    its been awhile since i used a gun with a vent in the cup, but i recall in the day always looking for something to stick in the small hole to clear the vent
    or you could stick your finger over the air cap, charge the cup,and make a pressure pot out of it, lol
    now days we use those 3m pps cups, no vent, and they will even paint upside down, and paint flow is conssitant, and they wont leak.
    good luck with that lacquer job
    skull
  7. SlowandLow63
    SlowandLow63
    from Central NJ
    A piece of welding wire will do the trick, or a paper-clip, torch tip cleaner, etc.
    I've always thought about converting to the PPS system but never have. Its awesome that they spray upside down. I wonder if they can spray in space???????????? :D :D
  8. skullhat
    skullhat
    yes, that part got figured out, lol. its a rule of painting that when in the booth, none of those items can be found within a 100 yard radius.:)
    skull
  9. SlowandLow63
    SlowandLow63
    from Central NJ
    You don't weld or cut with a torch in your paint booth?? :D
  10. skullhat
    skullhat
    .............sometimes, you know, when you see that last little spot , just as you're ready to paint:eek:
  11. pimpin paint
    pimpin paint
    from so cal
    Hey,
    It sounds like the blocked vent tube/hose is/was your problem.
    What is your lacquer thinned at? Most lacquers are thinned at 150%-175%. If you're tryin to shoot your top coat on thick, that could spell trouble up the road, to say nothing of poor gun performance!
    NEVER attempt to clear the fluid cap or fluid needle of a spray gun by placing one of your fingers over the air ports! Even at 65# at the gun, pressures at this level can force paint & thinner into your skin, and into your blood stream causing blood posioning. I once had an old painter friend who we buried with nine fingers, he lost one doing just what I advise against!
    Swankey Devils C.C.
    '' A legend in his own basement"
  12. jimi'shemi291
    jimi'shemi291
    PimpinPaint: Man, I am glad you mentioned that SAFETY tip!!! It would be REALLY easy for any guy to fall into that situation, if you got frustrated enough!!! THANKS
  13. fred56
    fred56
    Pimpin paint - The thinner was reduced 125% as per their instructions. Do you think I should thin it out further?
    Thanks - Jerry
  14. pimpin paint
    pimpin paint
    from so cal
    Hey Jerry,
    I'd suggest this: Empty and clean the spray gun completely! Pour some fresh thinner into the gun and check the spray pattern on some 36" paper taped to the shop wall. Be sure to adjust the gun for a full, clear pattern, no fuzzy margins, no funny areas in the middle of the pattern. If what you find is that you can't get this from the gun, you've a gun problem, not a paint problem. Repair/replace the gun and try a pattern, again with the 36" paper, this time with correctly thinned paint material. @ 150% with a slow thinner and correct pressure at the gun, you should have no trouble laying down a wet spray pattern. Be sure you're giving it a full 50% overlap on your spray pass. On some of the cheap-ass HVLP guns you have to wait for proper atomization at the spray tip. If you're going too fast for the gun, you'll produce a dry, uneven spray pattern.
    Swankey Devils C.C.
    "I liked the old millennium better"
  15. fred56
    fred56
    Thanks for all the information it really helped. I reshot all the bad areas and it came out perfect.
    Jerry
