Technical Split Exhaust on a Pontiac Flathead 8 (to get V8 Sound)
Discussion in 'The Hokey Ass Message Board' started by leroycash, Jul 13, 2018.
  1. leroycash
    leroycash
    from houston
    A few years ago I read a post claiming you could get a V8 "sound" out of an Inline 8 engine if you split and ganged the eight exhaust ports in a certain way based upon your crank configuration. It had something to do with a 4-4 vs. 2-4-2 crank configuration like on a Packard 8. I have a 52 Pontiac 8 with the standard High Compression head and 2 bbl intake. I'm not sure what to look for with this Pontiac crank configuration as it relates to sound. That's my first question. My second question would be which cylinders should I gang to get that V8 sound? I'm under no delusion I will get much performance out of splitting the exhaust. I just want better sound when I cruise.
  2. RichFox
    RichFox
    I would guess you need to put every other cylinder, as they fire, in separate headers. All the even firing in one. The odd in the other. May be hard to do without 8 exhaust ports. And V8s are not usually done that way anyway.
    leroycash likes this.
  3. BBFHY
    BBFHY
    from Texas
    V8 dual exhaust sound is syncopation. Below L is left bank, R is right bank.
    Chevy V8, using firing order -
    LRRLRLLR
    Flathead V8 -
    RLRLLRLR
    Send exhaust to each side of car like that, should get a V8 sound.
    Edit: Looked up Pontiac firing order. 16258374. Plumb odd numbers to one exhaust, even numbers to the other. Should get V8 sound. Assuming you have eight exhaust ports. May not be possible without.
    Hnstray and leroycash like this.
  4. belair
    belair
    1. H.A.M.B. Chapel
    Maybe it will sound like two four cylinder engines.
    Bandit Billy, Hnstray and leroycash like this.
  5. I'd have to do the math but there's more to it than just one cylinder routed here, one there. It also has to do with the firing intervals which depend on the angle of the V. Simple example, you can't make a parallel twin sound like a V-twin without changing the crank to mimic the V-twin's firing intervals. Maybe the straight 8 already mimics the V8's firing intervals? I dunno...
    That said, "make it sound like" is subjective. What sounds exactly alike to you may sound glaringly different to me. Splitting the exhaust may be worth it, I don't know, but from a theoretical standpoint you may not be able to get there from here.
  6. jimmy six
    jimmy six
    Ford flats had their own sound as the y-blocks and paired cylinder Olds. I'll bet it will sound good anyway you do it. Just remember it will never get the "twice pipes" sound of an inline six..
  7. samurai mike
    samurai mike
    why the hell would you want a straight eight to sound like a v eight?
  8. Rusty O'Toole
    Rusty O'Toole
    I'm with samurai mike. If you want the sound split the manifold and run 2 pipes all the way to the back of the car with your favorite mufflers.
    firstinsteele and leroycash like this.
  9. leroycash
    leroycash
    from houston
    Good point. Yes, there are definitely eight exhaust ports on the block. I'm wondering if the sequence is a straight alternating pipe-one then pipe-two or if there's something different in the sequence.
  10. leroycash
    leroycash
    from houston
    Thanks for the response, and wow, that's pretty interesting. Both V8 engines alternate the pattern on each bank in a similar way. I'm going to have to sketch this pattern out with the inline 8 firing order. You've got me thinking.
  11. leroycash
    leroycash
    from houston
    Ha! That would be disappointing, to say the least.
  12. leroycash
    leroycash
    from houston
    Good point. By interval do you mean sequence? It seems like the sequence alternating between two manifolds on the inline 8 could be combined similar to the left/right manifolds on a V8. It may look odd.
  13. leroycash
    leroycash
    from houston
    I don't know the twice pipes sound. What's that?
  14. XXL__
    XXL__
    Embrace the engine you have... or if you can't, swap it out.
  15. leroycash
    leroycash
    from houston
    Fair question. Right now its just a what if question. It may not make a better sound.
  16. leroycash
    leroycash
    from houston
    Yes, agreed. I think that's the plan. My only question is which exhaust ports go to which pipe? I may not have that many options given the tight real estate on that side of the engine. But as a hypothetical...
  17. RichFox
    RichFox
    V8 or straight eight they both fire every 90 degrees
    Hnstray, leroycash and XXL__ like this.
  18. leroycash
    leroycash
    from houston
    True that.
  19. leroycash
    leroycash
    from houston
    Yes.
  20. 302GMC
    302GMC
    from Idaho
    Split it 5 & 3. The sound is unlike anything else you'll hear - one pipe chases the other as the hydro shifts. Routing the dual side headpipe around the heater is the hardest part.
    leroycash and firstinsteele like this.
  21. F-ONE
    F-ONE
    from Alabama
    Just run eight pipes all the way back.
    VANDENPLAS, Deuces and leroycash like this.
  22. leroycash
    leroycash
    from houston
    I never thought of this. Any idea which cylinders you would put on the 5 and which ones on the 3? One thing's for sure, you can't do that with a V8! There's gotta be a quick way to mock this up.
  23. 302GMC
    302GMC
    from Idaho
    5 in the stock flange, 3 up front. Last one I did, I cut the manifold into 2 parts & plugged the cuts, then used a Gotha weld-in flange in the side to better clear things going down.
  24. firstinsteele
    firstinsteele
    I did this [ 5&3] with a straight eight Buick in the '50s. Awesome sound. My brother still talks about it.
    Ben
  25. Bart R Orlans
    Bart R Orlans
    I know I'm late to the party here, but this is a photo of the port side of my former Pontiac straight 8.
    Hnstray likes this.
