Projects Splicing a '35/'36 and a '40 dash
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Dec 19, 2018.
  1. sloppy jalopies
    sloppy jalopies
    Forgot to take progress pix...
    the '35 was rusted off all the way across the bottom...
    the '40 had [2] 3" gauge holes cut in above the instrument cluster...
    I cut off the savable '35 top from the nasty bottom...
    cut the nasties off the top of the '40...
    left a little extra on both, carefully trimmed them down to fit...
    took about 1/2" from each end...
    I usually butt weld but I let the halves overlap so I can weld inside and out for extra strength...
    small pie cut on each side of the '35 waterfall to let the '35 flatten [front to back] and better match the '40.
  2. falconsprint63
    falconsprint63
    from Mayberry
    Nice job. Turned out a heckuvua lot better than my attempt to do the same with a 39 dash.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  3. sloppy jalopies
    sloppy jalopies
    love cutting up those '38,'39, '40 dashes...
    '33-'36 upper dash sections help mounting '38-'40 dashes into an older car's cowl...
    they create a "tough to make" compound curved, arched, 90*… it may also let you run the crank out windshield in a '33-'34 hotrod...
    kidcampbell71 likes this.
  4. sloppy jalopies
    sloppy jalopies
    The '35 dash bends 90* down about 1.25" over the front edge, by relocating the D nuts it "can" be bolted into a '33-'34 car cowl...
  5. sloppy jalopies
    sloppy jalopies
    Pic of the half '35 / half '40 dash in my '30 coupe...
    1971 ish ford truck speedometer...
    RICH B likes this.
