So, while i wait for ignition parts to reach my mail box i started the -29’s diet. Fenders gone, side steps gone , tail rack gone. But i got stuck on getting rid of the splash aprons; how do i get them off? Do i have to lift the cab, or are there some loop hole? Grateful for all tips! //Magnus
Undo/remove the body bolts that go through the splash aprons...they will slide out, but it often helps if you can 'lift" the body a bit (a pry bar works for this).
Thanks! I suspected it would involve body bolts but hoped it wouldn’t... Skickat från min iPhone med H.A.M.B.
Often the splash panels are bolted to the frame. You have to lift the body or tear out the bolt holes. Get under the car and look up at the frame.
