Has anyone here seen one of these body's in person? I am considering replacing my roadster body with a sedan or 3 window body and speedway looks like it is a pretty good deal. No need for flaming about it being glass. It is what it is. Thanks ahead of time.
I'm not a glass fan but I have looked over the Speedway glass 3 window and it looks like a good value for the money. I always worry if what you see is what you get?
Thats why I'm asking if anyone has actually seen or built one. I can't find any info on ROD ACTION as the builder either.
Rod Action was a hot rod magazine back in the eighties. They may be referring to a tech article in the mag about the body.
Don't tear a running hot rod apart.....build a new hot rod.....then there will be 2 hot rods instead of one.
Hi, I believe the Rod Action bodies are built in Canada which is a good thing. I built a Rod Action roadster a few years a go and found it to be superior to others with good fitting parts, heavy gauge F.G. with good internal supp ort. The body parts also fit well. I am assuming they are the one with the RED Gel Coat Finish.? Larry
