https://www.speedwaymotors.com/Speedway-GM-Manual-Trans-to-Flathead-V8-Adapter-GM-Clutch,11098.html is it the camaro v8 t5 trans i.e. does it want the 26 spline input shaft that is 8 3/4 inches total rather than the more common 9 1/4 inch long 'versions' - i.e. mustang etc etc or is this bell housing adaptor 1/2 inch shorter total than the ford one is the register 4 5/8''
I'm sure someone will be along with an answer but I would reach out to speedway. They have always answered me fairly (next day)quickly and correctly. I have only asked questions online so I can't speak for their technical skills over the phone.
A 4 speed muncie A camaro v8 t5 Do they share the same input shaft kength Does the v8 camaro bell jousibgvwith the 15 degree slant differ from a upright earluer bell housing I want to know if usinv yhis adaptorcand a chevy eared t5 case. Do i need the b8 camaro short input shaft
Also why would you not advertise the fact you can use a nv4500 5 speed two wheel drive transission. It being a true top loader
