Technical SPARK PLUG GAP ADVICE NEEDED FOR ELECTRONIC DISTRIBUITOR
Discussion in 'Traditional Hot Rods' started by J2X, May 20, 2019.
  1. J2X
    J2X
    Would appreciate advice as to the correct spark plug gap when using Joe Hunt Mag Look Distributor in 49-53 8BA Ford with Autolite 216 plugs - Engine has Offy heads, 2 Strombergs on Offy intake, Isky 400Jr. cam, and headers - Thanks in advance for your varying answers
    Dave W
  2. Doublepumper
    Doublepumper
  3. Jimbo17
    Jimbo17
    I remember the day's of indexing the plugs so that the gap faced in between the two values. I still have all of the index washers I used to use when we were racing.
    Jimbo
    Deuces and dana barlow like this.
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    Mag-Look? Just set them at .035" like everybody else. Jack E/NJ
    Deuces and Truck64 like this.
  5. Mike VV
    Mike VV
    from SoCal
    J2X -
    Have you...say...called or e-mailed Joe Hunt..?
    Seems to me that that would be the most appropriate location for the best (I hate that word) answer..!
    Mike
  6. Atwater Mike
    Atwater Mike
    If you call 'Joe Hunt'...ask for Roger Gleason, as Joe's been deceased these 15 years...
    but with that distributor, its common application would be preferable.
    The distributor doesn't know what engine lies below, and the HEI design was of GM origin...
    Good question, actually.
  7. revkev6
    revkev6
    from ma
    Yes and no... the compression matters. More compression requires tighter gap.
    Sent from my SM-G965U using The H.A.M.B. mobile app
  8. jimmy six
    jimmy six
    There are pros and cons about those magneto look-a-like units. I'd always have my previous unit along with me on a trip including the correct tools and a timing light.
  9. Truck64
    Truck64
    from Ioway
    ... yet a lot of people open up the gap and/or use a hotter plug..
  10. revkev6
    revkev6
    from ma
    Odd... I learned how to gap plugs from the msd instructions that came with my distributor... low compression motors they spec'd up to .050+ gap
  11. Truck64
    Truck64
    from Ioway
    I agree, though wide spark plug gaps puts the stock points style rotor and cap under a lot of strain though, they have closer spacing of terminals and misfire or arcing can result.
  12. duncan
    duncan
    .045 on my 276 with 9.0/1 using MSD pro billet and box.
  13. porknbeaner
    porknbeaner
    electronic distributers commonly gap between .040 and .044. Joe Hunt should have info on what the recommended gap is for that particular distributer. Tyr google; google is your friend.
