Sonic thickness testing
Discussion in 'The Hokey Ass Message Board' started by Jmountainjr, Nov 20, 2010.
  1. Jmountainjr
    Jmountainjr
    I have a new mid-level sonic thickness tester to check some cylinder blocks. I'm looking for someone with some experience to tell me what they have found / used for sound velocity numbers for 1970 / 1980 SBC factory blocks. I want to verify what I've found to see if I'm in the ballpark.
    Thanks,
  2. Can't you find a section of the block with a known thickness and tune it such that you know what you're working with? This is how I saw a guy do it on some flathead blocks for me?
  3. Jmountainjr
    Jmountainjr
    Yes, I did test a place on the block that I could measure the thickness. I was just looking to confirm if my meter was in the ballpark.
  4. fab32
    fab32
    You just did your own verification........................you took actual measurement and your meter verified.
    Frank
  5. Doesn't matter - you set it up for a "known test" . . . you'll be fine!
