some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. barrnone50
    barrnone50
    from texas
    Very nice!! Craftsman at work!! Thanks for the sharing your work.Sure like the welds!!
  2. tunram2quad
    tunram2quad
    Plenty of cool ideas put to fine craftsmanship.Nice welds also.Thanks for sharing
  3. cornfieldcustoms
    cornfieldcustoms
    thanks guys, yes i do Tig weld at my shop on most small parts, and some sheet metal work.
  4. MTR-HD-Ordie
    MTR-HD-Ordie
    As everyone has already mentioned, simply amazing talent! It appears your time is in very high demand, I just wish I lived 1000 miles closer!
  5. chevy3755
    chevy3755
    nice fab work..
  6. cornfieldcustoms
    cornfieldcustoms
    finished out the monthly budget on this car this week. worked on the spreader bar, head light stands, and fuel tank mounts.
    the head light stands needed the ball socket cut loose and tilted forward to work right with the 32 headlights
    welded in section of 1 7/8 tube for the front spreader bar
    then made the gas tank stands, and hold down straps
  7. cornfieldcustoms
    cornfieldcustoms
    finished up this sheet metal air management box for a fellow hamb member
  8. hammered30
    hammered30
    from west aus
    You sure do quality work in your shop. thanks for taking pictures and posting
    Cheers paul
  9. cornfieldcustoms
    cornfieldcustoms
    some more work on the coupe
    also please follow me on instagram for daily photo updates of the shop #cornfieldcustoms
    the old section of the rear passenger quarter panel, it was a little beat up and had some rust. so i decided to replace the whole corner.
    the old
    the new all welded in, still needs a little metal work
    did a little more tweaking on the trunk opening to get the deck lid fitting good
    a shot of the deck lid first row of louvers started
    all louvered up
    found another hidden rust hole
    patch panel all tacked in place
    ready to put in the passenger side wheel well
    all tacked in place
  10. 40Standard
    40Standard
    from Indy
    what the hell is instagram? I'm old. nice work kid
  11. Rattaxi48
    Rattaxi48
    from ohio
    damn nice work may have to stop in and check out your shop next time im in the area
  12. 64ONEOFF
    64ONEOFF
    from Md.
    Nice work, I wish you where closer, I love to get a louvered roof in my 31 sedan
  13. cornfieldcustoms
    cornfieldcustoms
    thanks guys, rattaxie stop by any time.
  14. cornfieldcustoms
    cornfieldcustoms
    more progress on this one, had to modify the new stainless head light stands to work with the car
    got both lights mocked up, mounted them low for a more aggressive look
    brake/ clutch master cylinder mocked up
    had to machine these support blocks/ spacers for the deck lid hinges. they help support the sheet metal on the body and are counter bored to allow the raised area around the thread boss on the hinges
    new hinges on
    a shot of the support braces installed
  15. Grumpy
    Grumpy
    from NE Ohio
    Great work man!
    Like how its coming along.
    Been following your progress on ig
  16. MedicCustoms
    MedicCustoms
    Real cool work. Keep the pics coming. thanks
  17. ahhhhh very impressed and happy I came across this site. Very inspiring. Working towards getting my shop going slowly but surely. We all know the amount of time it takes to acquire all the tools and knowledge and it seems like you have most of that. It always boggles my mind that people can do this for a living, around me just seems like everyone builds stuff themselves. Glad your making a living doing it. I'v owned my own printshop for the past five years and love it, but I want to have more time to build hot rods and customs. Maybe I can swing through sometime, I'm in PA.
  18. straightshooter
    straightshooter
  19. johnod
    johnod
    Very nice work.
    How do you make those large recessed or raised panels as in post 114?
  20. Very nice work,,HRP
  21. cornfieldcustoms
    cornfieldcustoms
    for the large raised panels i use a bead roller with a step die, and do the shape all the way around
  22. WB69
    WB69
    from Kansas
    Like the front window art!
  23. cornfieldcustoms
    cornfieldcustoms
    made more progress today. both doors need lower door skins, so i started on the passenger door today. i figured it would be best to put a full lower skin on up to the belt line. that way if you looked inside the door you could not see the weld seam.
    started off by making a paper template, then transferring it to some sheet metal
    old door skin removed, all the loose rust scale removed and some black primer sprayed on
    i forgot to take pics of me making the skin itself. pretty much i used the english wheel to get some crown on the panel, then ran it through the bead roller to make the lower body line. used the brake to bend the edges up. i will snap some pics of the making of the skin tomorrow when i make the driver side.
    new skin clamped up
    inside edge like a factory skin
    inside of the weld seam, cut out the inner bracing so i could get in to hammer and dolly the weld seam area
    after some welding, grinding and hammering and dollying this is what i came out with
  24. SakowskiMotors
    SakowskiMotors
  25. 48reo
    48reo
    good stuff man!
  26. Gator
    Gator
    Very cool stuff, talked to you for a bit at the Road Rockets show in Indy.
  27. cornfieldcustoms
    cornfieldcustoms
    so i went to re skin the driver door today, when i got the old skin off there was a lot of rot and pin holes in the bottom of the door frame, so i had to make a new door bottom.
    after a couple hours of bending, drilling and bead rolling i came up with this
    after a few more hours of cutting, welding and grinding
    had to do some steel buck rivets
    pretty much all finished
    in black primer ready for the new skin
    overall i think it turned out pretty nice
  28. hemikev
    hemikev
    man ur shop does some nice work , awesome
  29. cornfieldcustoms
    cornfieldcustoms
  30. reallyrotten
    reallyrotten
    WOW just awesome work!
