some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. cornfieldcustoms
    cornfieldcustoms
    the center of the D was done on the hammer as well. we clamped the center section in the die set using a piece of flat stock to bridge the gap, and hammered it in as the last step. it was running i hammer mode to get a good enough hit to press the dies together. yes it is a baileigh MH-19
    bigheadbaxter, loudbang and JOYFLEA like this.
  2. cornfieldcustoms
    cornfieldcustoms
    lots of things have been going on around the shop and havent had a a ton of time to post much so here is a recap of the more interesting things
    had to make a brake booster recess for a customers firewall. all hand shaped
    had an OT fuel tank to make turned out pretty nice so i figured i would post it. all hand shaped from aluminum
    finished up the metal work on the cowl area of the Fiat topolino
    this one was a fun one. this 39 chevy was hit going to the local cruise night a while back. they had a hard time find a new door or fender so i was in charge of fixing what was there
    started with beating the fender back into shape
    mostly roughed out, this was as far as i was going to take it until i could bolt it back on the car
    then it was time to start on the new door skin
    the plan was to wheel out a new door skin and replace everything from above the body line down. of course when we started digging we found more problems. once the door panel and skin were removed there was a lot of damage done by previous repairs to the inner door frame. so that took some time to fix
    as you can see by the final inner pic there was a lot of repair work to be done
    putting the new body line in the new door skin
    i didnt take a ton of pics making the skin or wrapping it on the frame
    then the rest of the came in for me to fit the parts to
    started to finish up the fender
    and all finished up ready to go back to the body shop ** note, we were not doing the repair on the lower cowl, that is the body shops repair**
    and a before and after shot
  3. oj
    oj
    Very nice work, that riveted cowl patch is a graphic example of the difference between craftsmanship and a repair.
  4. bct
    bct
    Love the recessed booster!
    loudbang and cornfieldcustoms like this.
  5. oldsjoe
    oldsjoe
    Amazing work Mike and to think you did it all in less than an hour!! Joe
    Sent from my SM-G900V using The H.A.M.B. mobile app
    loudbang, Jet96 and cornfieldcustoms like this.
  6. Dino 64
    Dino 64
    from Virginia
    Always enjoy your posts. Excellent work as always.
  7. woodbutcher
    woodbutcher
    :D Superb as usual sir.
    Good luck.Have fun.Be safe.
    Leo
  8. The 39 guy
    The 39 guy
    Amazing work as always! Thanks for taking the time to share your work.
  9. mrquickwhip
    mrquickwhip
    I never get tired of looking at your work.....a true craftsman
  10. cornfieldcustoms
    cornfieldcustoms
    thanks for all the kind words guys
    oldsjoe and loudbang like this.
  11. I'm always impressed when viewing this page. :)
  12. Stogy
    Stogy
    The Car Boo Boo fixer and more...always amazing things to see...always a wow factor. Great work and thanks for sharing Mike.
  13. MP&C
    MP&C
    Inspirational work Mike!
    lothiandon1940 likes this.
  14. cornfieldcustoms
    cornfieldcustoms
  15. YJ4000
    YJ4000
    Looks Fantastic!! You very, very good at what you do. Very may be an understatement but you get the point.
    Ryan
  16. raprap
    raprap
    from Ohio
    Mike, as always, you make it look easy! Great Stuff!
  17. cornfieldcustoms
    cornfieldcustoms
    been working on a making some new quarter panels for a model a sedan we are working on
    making paper patterns
    laying the pattern out on steel and cutting it out
    shrinking the rear compound curve into the panel
    test fitting to the car and laying out lower body lines and wheel arches for the larger tire
    lower body line and wheel arch put in
    turning the edges of the panel to fit in the factory seams, as well as the lip around the bottom of the body and wheel arch to attach the inner wheel well to
    inner wheel well made in clipped in place
    a little more finish work and weld up the inner wheel well and this one will be finished, not to do the other side and a new rear panel
    JOYFLEA, 40LUV, jhughes76 and 7 others like this.
  18. Really great work Mike !
  19. oldsjoe
    oldsjoe
    Looks so easy! Why can't I do it! Mighty fine Mike! Joe
  20. woodbutcher
    woodbutcher
    :D That`s great.Is there anything you CAN`T do?
    Leo
  21. boring-hop-yard
    boring-hop-yard
    Wow, nice work!
    Thank you for sharing!
  22. Johnboy34
    Johnboy34
    from Seattle,Wa
    Jeez, I'm jealous. :D
  23. The 39 guy
    The 39 guy
    Just amazing!
  24. Impressive!
  25. mgermca
    mgermca
    Lovely. Not bad for your age :)
  26. MIKE STEWART
    MIKE STEWART
    Nice metal work - thanks for sharing.
  27. YJ4000
    YJ4000
    Great job!! Just amazing. Thanks for sharing.
    Ryan
  28. whodaky
    whodaky
    from Aust
    Beautiful work thankyou for showing us your's and your shops skills.
    Geoff aka whodaky
  29. GASSERBOB
    GASSERBOB
    from USA
    You guys are excellent craftsmen. I'll tell you that. I cant believe it. Beautiful. Bob..................
