Projects Some of my work.....
Discussion in 'The Hokey Ass Message Board' started by josh highley, Oct 30, 2013.
  1. josh highley
    josh highley
    Some of you have probably seen a bit of my work from a couple of my build threads. I figured I would start a thread to my post pics of everything I work on, instead of starting a new thread for each project. I plan to keep a steady stream of pics coming. Please take a look at feel free to ask questions.
    I hope this is ok. If not please let me know moderators. I work on a little bit of everything, but I will only post pics of the on topic stuff here. I upload pics of almost everything I do on my Facebook page.
    Here are a couple links to builds I have done on here
    32 5W build - http://www.jalopyjournal.com/forum/showthread.php?t=758109
    33 Continental - Chop, Channel and some rust repair - http://www.jalopyjournal.com/forum/showthread.php?t=780429
    30 A Roadster - quarters and sheet metal repair - http://www.jalopyjournal.com/forum/showthread.php?t=769963
  2. josh highley
    josh highley
    Here is a link to my old 1930 A Coupe -
    http://www.jalopyjournal.com/forum/showthread.php?t=784415
    I started from a bone stock original and built everything you see here. Although I built the frame, I could not have done it with out the help of Jack (doose32) and Drew (32coupedeville) Strunk of Dropped Axle Productions. Everything else I did in my garage.
  3. josh highley
    josh highley
    Here is a floor pan piece I did for fellow Hamber barry2952 . It is for his 1930 Ruxton. He sent me a couple pics and dimensions. I knocked the piece out and sent it to him. The beads were rolled with my Baileigh Industrial Bead Roller. Great piece of equipment.
    Old versus new
    New panel installed
  4. josh highley
    josh highley
    Door skin for 32 5W today.
    sorry for the blurry pic
    Done and metal finished
  5. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Lookin good brother ;)
  6. josh highley
    josh highley
    Thank you Shane!
  7. josh highley
    josh highley
    I am working on a 1929 A pick up right now. Rust repair, straighten cab out and will get a 3" chop.
  8. josh highley
    josh highley
    Removed the gas filler
    Filled and metal finished
  9. josh highley
    josh highley
    Had some rot in the drivers side cowl panel. Cut out the bad
    Done
  10. josh highley
    josh highley
    Driver's side upper hinge had pulled away from the a-pillar. Door didn't fit worth a crap
    Fixed
  11. josh highley
    josh highley
    Nothing really special here, but I thought I would share this. I cleaned, sealed and painted the chassis.
    1932 Hupmobile and was built by Dropped Axle Productions here in Cincinnati, OH. You will not find a better group of guys to build you a chassis for almost anything you are working on. Jack & Drew Strunk are member's here (doose32 & 32coupedeville) Check them out!
  12. 80WTI
    80WTI
    Great job, you do a quality job mate. Do you tig or oxy weld your panels? thanks for sharing some pics. Lee
  13. josh highley
    josh highley
    Thank you!
    I do all my sheet metal work with a MIG welder
  14. chriscris
    chriscris
    Do you tack the repair panel several times, cooling in between? That cowl patch is straight as an arrow.
  15. josh highley
    josh highley
    You got it. Several rounds of tacks, letting it cool in between each round. Thanks!
  16. josh highley
    josh highley
    Here is a shot of the chop all finished and steel top in place. I didn't want to flood this page with pics, but you can look at my facebook page or photobucket for a lot more pictures of the chop.
